1 - 20 of 42 Posts
I'm considering buying a cordless impact wrench, most likely a Makita. I could spend much less, but don't want to cheap out on an import tool. I think a cordless should satisfy my needs
If you have an impact wrench, do you consider it indispensable, or just really nice to have?
I have a Snap-on cordless impact and it's one of the best tools I have ever bought. 450 ft lbs of torque and lithium ion batteries. I've taken lug nuts off with it that most air impacts at work couldn't take off :)
Which Makita isn't made in Japan or China? Japan may have the edge on quality, if those are the wrenchs you've been looking at, but, being a USA citizen, I'd still consider them imports. Oh, nm, I think you meant if you're going to buy import, you don't want an inexpensive import.
Anyway, IMHO, they're mostly a luxury item. If you're in a hurry or are lazy, they're great to have handy. They can also be an alternative to a breaker bar.
You can't use the vast majority of them for accurately torquing high spec nuts (e.g., hub nuts), so you'll still need a good torque wrench.
Really nice to have. Definitely not a necessity. A breaker bar is one of the best tools I've gotten. The impact I use mostly to get the lugs off but a lot of bolts are just too restricted for it.
I like having an impact wrench but found I am limited with WHERE I can use it due to the size. So I end up using sockets and wrenches a lot.
I have a Craftsman cordless impact wrench. One of the best tools I've ever invested in as a weekend warrior mechanic. Although, I've become my friend's AAA service when they have flats, lol.
I own and couldn't live without two of them. 1/2 drive and 3/8 drive. mine are both pneumatic, but the air compressor is another gotta have tool.
I have a Ingersoll Rand pneumatic (the best of the three), a Harbor Freight electric (does yeoman duty for me), and a "Trades Pro" 24V battery (just the thing to take to the boneyard). Do I NEED them? No, I can get things apart with breakers and cheaters. Do I USE them? Oh, $PROFANITY yes!!! Why bust MY gut when I can use mechanical advantages like impact wrenches? :diablo:
(The "Trades Pro" was bought on a Black Friday for about 75% off MSRP. I'd rather have a good Makita, but eh, couldn't afford.)
I bought a battery powered Milwaukee one a few years ago on sale. 450lb-ft (or 475lb-ft can't remember) and came with 2 batteries for pretty cheap. The battery one is great because we build a lot of (relatively) heavy duty frames at work, so I can use it there.
The nice thing about the impact, I have found is that it breaks a lot of rusty bolts free a lot easier. Also, with suspension parts you have access to, it is pretty fast. I have now twice lifted a car's end using a breaker bar/jack on a VERY rusty bolt that had 2 weeks of daily penetrating fluid spray and wouldn't break free, yet an impact broke it free almost immediately.
But as it was stated, it's generally more of a luxury than necessity unless you are doing car work for a job (time = money).
Stephen
I have 1/2-3/8-1/4 snap on battery impacts, also got Mac 1/2-3/8 pneumatic, Milwaukee 3/8-1/4 battery. Use at least one of these every day wouldn't go anywhere without them.
Do pneumatic 1/2" drive wrenches have more torque than the 3/8" drive units?
My 3/8" unit works okay but seems anemic at times.
Yes, they do. Normally anyways, I'm not saying that they don't make 3/8" drive ones that are just as powerful as some 1/2"s, but normally they don't have as much. for example, my snap-on 1/2" drive cordless has 450ft lbs, while my 3/8" drive cordless has only 150ft lbs. This is cordless of course, but it will be close to the same with pneumatics also
I bought a 24V dewalt cordless impact about 15 years ago(, and have replaced the batteries twice,) but almost never use the air impact anymore.
I live in the South, so YMMSV. :)
The last thing I had to get the big tools for was the harmonic balancer bolt, And I ended up with the 3/4" breaker bar on it; with a strap wrench supported by a jackstand holding the balancer, lol. I was Standing on it when it popped loose, IIRC.
I use a cordless impact at work ( pipe trade ) all the time, the Makita seems to be holding up fairly well. Its an indepensable tool at work, so is the portable bandsaw.
I have a pnumatic impact at home for the bigger bolts with automotive work, but I tend to find myself breaking bolts loose with a wrench and zipping them out with a drill gun. I think a cordless impact would be a great tool for even the average wrencher, as long as youre going to put it to use.
To me, most suspension work is not possible w/o an impact gun. A good example is that tension rod nut where there is nothing holding the rod steady.
There are a lot of tools that you don't realize their value until you have one, then you wonder how you ever did without it!
Al
Stephen
Milwaukee is the bees knees and the cats ass
Impact wrenches are good for removing latch pillar posts on the older muscle cars if you have to. I had to use it on my Torino when repairing the door jamb.
I also used it to break the head off of the lower interior quarter trim sheetmetal screws to remove the trim piece. Both sides were frozen solid due to rust.
I also used it to remove the one of the fasteners on the throttle position sensor on the Underbird. It had a Philips head and was at the point of stripping when I decided to use the impact wrench on it. It came right out.
I always feel like Rambo when I use an impact wrench on anything.
I'm so spoiled since I started using them. It is something that once you use, you will ALWAYS want it! A good (dealer grade) scan tool probably falls into that category as well. You don't absolutely need it, but it is a nice have. I have taken off bolts in weird places that probably would have taken 30 min (with backup wrenches and 1/32 turns) wheras an impact can do it in seconds.
I don't think an alternator pulley bolt can come off without an impact. If it could it would probably be a real PITA to do.
For smaller fasteners a good cordless drill with a clutch and socket adapter works very well.
1 - 20 of 42 Posts
