Ok we've been trying to get these developed for a long time but working with StreetRacerParts.com we can. All we need is 10 orders to get the Halo Reverse Indiglo set produced for the 1994-1995 SC's! If you're interested click the link below and sign up! You're credit card won't be charged until we've reached 10 orders!
http://www.streetracerparts.com/index.asp?PageAction=Custom&ID=22
they'll look kinda like these ones for the 89-92's
Pretty much... the 93's are kinda the orphans cuz they're a 120 but they're still different than the 89-92's by a small portion. My recommendation would be to swap in a 145mph out of a 94/95 which is a fairly simple swap.
johnwartjr said:
Looks interesting, how difficult an install is this? Any install guides online for reference purposes?
Is the mod "reversable" should I decide I not like it (meaning, does it glue to my current guages, or ?)
I don't know how difficult the install is yet until I get a set but guys with 89-92 sc's have installed the gauges from ProCarParts just fine, but they won't make a 94/95 set. And it should be reversible I don't believe it glues onto the old gauges
They are very easy
I have a set on my 92...I just simply peeled the old one's off and these stuck to the glue that was currently there. You do have to remove the needles which is very simple with a set of needle nose. Just don't pull hard...I learned that. You might need to use some new glue if your's isn't really sticky. Took me like 30 minutes. The hardest part was wiring them to the light switch...and it wasn't even that hard.
My gauges:
It's hard to drive at night because the glow just kind of makes you stare
but I sure do like them
