1 - 19 of 19 Posts
Hi Everyone,
Has anyone tried to retrofit the Autolamps and the Electronic Climate Control? Those are both nice features that I would like to have. Thanks!
Discussion Starter · #3 ·
krusher said:
I thought it was standard for the 96/97 models to have those features.... wow.
I wish!! It doesn't even have Keyless Entry :eek: (my Clifford fixed that, though :D). It's just a simple PEP157a (I think that's the pkg no) with the Sport option.
I have the auto headlamps on my 94, come on right around dusk - i bought it that way, then again it also came with a kenwood deck so i dunno if they are stock or not.
The only thing i dont like about them, is that they stay on for 30 seconds after i shut the car off, and i cant turn them off at all at night...
I have no clue about the auto headlamps, but I looked into getting auto climate control for my 97. From what I gathered, it will take the wiring harness for the console from a bird that has climate control (something about computer connections...), the actual unit (I have one for sale), outside temp sensor, and the inside temp sensor. I never got this stuff so I am not quite sure if it will work or not but my instinct tells me that this should do it.
--Craig
--Craig
Don't hold me to this, but I thought something about the climate control came up in another thread, and the guy gave up because it was such a hassle. He said finding a spot for the sensor's was a real pain.
On the other note, i hate the auto headlamps. maybe just my need to be in control, but the last thing i want is my car making decisions for me. that, and i dislike running my lights when i can see perfectly fine. oh well.
On my 97 I had a spot for the sensor. Of course they were sticking anything on the the last cars off the line.
-- Craig
G
hmmmm..... almost every bird I've owned
88 Turbo, 95 LX, 97 LX
had these options.... except my 92 sport. That doesn't but oh well.
Was your 'Bird badged an LX from the
bbickers said:
Hi Everyone,
factory and do you know your car's build date?
Discussion Starter · #10 ·
Re: Was your 'Bird badged an LX from the
Would the model matter? In 1997, all you could get were LX's, right?
The build date is 9/27/1997. Ford has not been too forthcoming with window sticker info. Not real sure why. They won't even tell me the originating dealer!!
Re: Re: Was your 'Bird badged an LX from the
Yeah, some kind of privacy thing, but your service writer
can bring up the delivering dealer anytime he wants to.
IF all models built in '97 were LX's (as common mythology
perpetuates), then you are correct. I asked because I don't
believe much of anything I'm told anymore unless it's from
someone on this board who has proven himself to be accurate
almost all the time.
I looked in my '97 Ford Thunderbird Sales Brochure and here's
what I found:
Thunderbird LX
PEP 155A
* Group 1: cast aluminum wheels/P215/70R15 BSW all-season tires
* Electric rear window defroster
PEP 157A
* All features found in Package 155A
* Group 2: 6-way power driver's seat, illuminated entry system,
and leather covered steering wheel and shift knob
* 4.6-liter SEFI V8 engine with speed sensitive steering
COMFORT AND CONVENIENCE
Luxury group: electronic semi-automatic temperature control
air conditioning, autolamp on/off delay system, power antenna,
dual illuminated visor mirrors****************************Optional
so the Autolamps and the Electronic Climate Control were
options and not part of the LX package.
The reason I asked your build date was simply to find out
how late in the production run your car was built. As I recall
I THINK the last build date was in very early October of '98
and I had thought that Ford maybe they might have been running
out of parts. Actually they were optional and, obviously not
ordered whan your car was built.
Hope this helps,
Have you tried turning the dial next to the dash dimming dial? If it's not there, the auto lamps aren't factory. With that dial you can turn them off (turn the dial all the way down till it clicks) and set the delay that it takes for the lights go off. (the further up you go, the longer it will take)
Yeah you can adjust the dealy on the headlights, so they can stay on for like 2 min. or go off almost immediately. And yes you can turn them off, by rotating that same adjustment all the way down til they go off. I have adjusted my delay , as well as turned them off at night...so it can be done:D
So, did anyone ever figure out if the auto-headlamps and Climate-control can be retrofitted? I just got my 97 Sport yesterday. I love it!! But I surely miss the:
dual illuminated visor mirrors.
My 97 LX had all of these items. Of course it didn't have the 4.6, or the Sport package either! :D:D
Dim Bulb
For turning them off at night, just go find the sensor wires and put a switch in the works, to turn the signal from the sensor on or off and presto, you should be able to turn your lights off at night... somebody correct me if I'm wrong
what I found:
Thunderbird LX
PEP 155A
PEP 157A
What I am EXTREMELY curious about is how many MN12's where built in 19941997 WITHOUT package 155A. Notice that you never, ever see a 94-97 with the factory hubcaps/wheelcovers? But they where available according to the brochure, and obviously the wheels where optional. And if you don't have 155A, you obviously will not have 157A, or the comfort/conveniance package. I have seen ONE 97 bird, denim blue, that was just like this. At some point some 15" 94-95 cougar wheels where thrown on there, but it had no options what so ever....so does anyone think any others where built like this?
For what it's worth, My '95 does not have autolamps ir climate control, but there is a connection behind the grille for an outside temp sensor, and there is a connector under the defroster panel for the sunload sensor... I also had the yellow wire under the hood for the cold coolant lockout for the SATC. That makes me wonder what I would be able to throw in...
Sounds like we have similar questions! I have access to a wrecked T-bird with both options. Just curious what I need to get out of the car, and how much trouble are we talking about?
I guess 94 packages were different. I got the auto climate control, power antenna and the dual lighted visors but no auto headlamps. Don't know what wheels it came with. One of the previous owners replaced them.
1 - 19 of 19 Posts
