hey i bought two autometer gauges today water temp and oil pressure i installed both of them but i ran into two problems oil is how did u guys fit the sending unit form the autometer oil its to long to fit into the stock location so i was wonderin if u guys had this problem or can help me fix mine and also what does a 94 thunderbird wit a 4.6 run for oil pressure bc i got a 0-100psi gauges..
100psi is more than enogh. as far as the fitment issue look around home depot for some brass angle fittings should be able to get one that will position the sender so it fits
3rd Gear Chirper
Oil pressures on my 97 4.6 using 10W30 as I recall:
Cold engine, idle: 70-75 PSI
Cold engine, off idle: 80 PSI
Warm engine, idle: 25 PSI
Warm engine, off idle: 45-50 PSI
