1 - 15 of 15 Posts
Just wondering if anyone knows of any mods that can be done to the M5R2 to make it stronger and handle more power?
Chris
Heavily Medicated Crime Fighter
I am having a hell of a time finding the proper 5.0 flywheel. I guess I will have to have the SC flywheel rebalanced. I went with the spec II clutch.
Mark
Mark
Mark,
I used like a truck flywheel for my swap.I can get you a brand new one for 125 plus shipping and a used one for 85 plus shipping. It will be the same one I have in and I am not having any problems.But you will need to get a truck starter.
Chris
That's a real low price for sure. I can get my SC unit resurfaced and balanced for 145 but I do not know which starter would go with it. I wonder if my stock starter will work.
Thanks
Mark
The ring gear is in a different location on the SC flywheel compared to the 5.0 part. I picked up a Fidanza 164 tooth aluminum flywheel for the, very delayed, T56 conversion.
Jedi Master
Does anyone have the complete list parts need for the m5r2 swap for the 5.0s? I'm trying to do this too.
You should be able to just use the SC starter. I plan on getting a new F150 starter from Dan when I finally do my swap.
Here is all of the info I got from 91 XR7, hope he doesnt mind that I posted this,
5 spd Parts needed for '91-93 5.0L MN12 using a M5R2 transmission..
'89-93 S/C 5spd Center consol Top
'89-95 S/C 5spd Shifter plate
'89-95 S/C 5spd Shifter handle
'89-93 S/C 5spd Brake pedal arm
'89-95 S/C 5spd Clutch pedal Assembly
'89-95 S/C 5spd Master cylinder
'91-95 S/C 5Spd Clutch interlock switch with harness
'89-95 S/C 5spd Clutch Resivour w/ Tube
'89-95 S/C 5spd Hydraulic Tube
'89-95 S/C 5spd Slave cylinder
'89-93 S/C 5spd Clutch Kit
'89-95 S/C 5spd Drive shaft
'89-95 S/C 5spd Tranny mount pieces
'89-93 S/C 5spd Tranny harness
'88-96 F150 5spd 5.0L Flywheel
'92-96 F150 5spd 5.0L Starter
'88-96 F150 5spd 5.0L Pilot Bearing (Standard 5spd ford Part)
Things to buy New..
Clutch Pressure plate
Clutch Disc
Clutch Slave Cylinder
Clutch Master Cylinder
Clutch Hydraulic tube
Pilot bearing
Main Seal
Tailshaft seal
Clutch cover bolts
Flywheel Bolts
S/C 3.8 flywheel will bolt right up to the 5.0 and after having it rebalanced you can use the stock S/C clutch setup. The starter for a 5.0 t-bird and either a M5R2 S/C or an AOD S/C are all the same. If you use the 5.0 F150 flywheel you will need an F150 starter to go with it as the flywheel has a different number of teeth than the AOD or S/C one does. My 92 5.0 bird has an M5R2 in it with an S/C flywheel, and the stock 5.0 starter. If I were to do the swap again I'd just buy the 5.0 flywheel and starter as it is much less pain in the butt than trying to find someone competent to rebalance the 3.8 one correctly and price-effectively. Hopefully this will answer some people's questions.
i do not know about the '94+ cars..
the MN12 uses the same starter in all the cars.. be it an auto or an manual, but i'm not 100% shure about the 4.6L and the 4R70W equiped cars?
Also the S/C and F150 flywheel are the same diameter witht he same tooth count (going by looks.. i never felt like counting them all :cool: ) .. the only this different, is where the ring gear is located.. the SC it's on the leading edge, on the F150 is on the Back edge of the FLywheel..
Hence the difference in the starters :)
you can rebalanced the s/c flywheel and use the orginal starter from a MN12..
Or you can buy a F150 flywheel and a F150 MANUAL starter
OR get a F150 flywheel and move the ring gear and use the stock starter :tongue:
Also the S/C (least '89-93) uses the same clutch as the '88+?? (M5R2 equiped) F150..
and on a 5.0L requiped car.. the m5r2 swap is a 2-3 day job working like 6-8 lazy hours a day by yourself :)
my 1996 f150 with a 351 uses the same starter as my bird and cat. had 2 replace the one in the truck and the cat:eek: i can verify numbers at work tommarow if anyones interested
yes my truck is automatic , i checked the catalog and the tbird starter is e9sz 11002brm for all applications, the truck uses that for an auto application and f2tz11002arm for a manual .
1 - 15 of 15 Posts
