Finishing up my DOHC swap and I need to know if any MK 8 or t-bird fuel lines will work? I'm putting in the avator motor, and I have no fuel rails, into my 94 t-bird.
Can i swap in return style, or do i have to change pump and lines?
Does anybody know which fuel rails will work??? Else I will be forced to go returnless style...
Going returnless is a lot more complicated than just replacing the pump and lines. I don't know what rails will work, but worst possible case you could take some other DOHC rails and if necessary cut the crossover tubes and replace them with appropriate length ones.
Mike
