1 - 2 of 2 Posts
Noticed my axle is leaking from the axle seal at the pumpkin.
Can anyone tell me the easiest way to replace this?
3rd Gear Chirper
Remove the axle, pull the seal out with a seal puller (or you might be able to pry it out with a flathead screwdriver). Then drive the new seal in with a socket, pipe, seal driver, whatever...just make sure it goes in squarely. Reinstall axle and you're done.
1 - 2 of 2 Posts
