1 - 14 of 14 Posts
i am getting a check engine light that comes on a few minutes after firing it up, but before reaching full operating temperature, then it goes away. it also comes on while traveling 75-80 mph and stays on until i slow down to about 70. my gas mileage seems a bit weak, too. finding an obd1 code reader around here to borrow is a chore, and i need a quick diagnosis. does this sound like bad o2 sensors?
I am not sure about your diagnosis, but do you know about grounding one of the pins on the OBDI port and counting the flashes? I did it to my '93 Ranger and it was a pain in the butt but it does work and you don't need a reader.
yeah, i heard of that trick and i got a thread going about that. not much help so far cuz i need a pic.
there ya go
what are you using to connect the pins?
In the pic its just a piece of red plastic so it would show up better. When I ran the test I used a paper clip, works great.
Baby Huey
I have to do pretty much the same thing on my 88 cutlass, except that both pins are in the same harness.
Does it drive better cold or after warm up, does it bog under WOT? Though intially it does sound like O2.
To pull EEC-IV codes jumper the top right plug of the larger connector with the small connector.
Any luck with the codes Mike?
i cant tell a difference whether its cold or warmed up. no bogging under full throttle.
i havent pulled codes yet.
Mike, either pull the codes or get a volt meter on the O2. Only other thing else I could come up with is MAF, but I lean toward O2. If so hurry up and change them and stop getting my headers dirty. ;)
Sounds exactly like what my truck was doing. Changed the 02 today and all is well
Discussion Starter #14
dont tell me that. i sold them along with my entire exhaust :(
yeah, late reply. sue me :tongue:
1 - 14 of 14 Posts
