i have a very bad vibration........ had tires rebalanced and it went away for a day or two... now is back...... d/s and ujoints are ok....... why would my tires and wheels keep going out of balance.... thanks... any help would be appreciated... and the vibration gets worse the faster you go...... thanks again
just had trans rebuilt...... and the problem got better after i had wheels rebalanced..... came back a day and a half later....... will check wheel brngs though... thanks....
now this is weird.... somedays the vibration is tollerable... and others down right violent what the heck... dont wanna just start throwing parts at it......thanks in advance.......
Sounds like the start of the 'high speed vibration' issue I had.
Are you mostly driving Interstate speeds?
yes... mostly highway speed...... but what gets me is its not bad all the time.....maybe its wheel brngs and half shafts..... but still you would think it would be bad all the time... :confused:
You buy crappy rotors and pads? What wheels are you running? Type of tire? Static or dynamic balance job?
Here is the post from my vibration problem...
http://forums.tccoa.com/showthread.php?t=79452
Rereading it, I think I was kinda freaked by finding out what holds the springs in, after the knuckle is off... :eek:
In the end, I had to replace the transmission; it probably died from the leak around the tailshaft, it causing a constant low fluid problem.
The u-joint was undetectable (by me) in the car; it was totally obvious when the shaft was out. Only one front bearing was toast.
I'd start with a detailed inspection of the driveshaft, off the car, if possible. While replacing it with a good unit, either 1-piece mark 8 or aftermarket, would be my personal recommendation... :D
I can't prove it, but I think the original cause of my whole vibration problem was the driveshaft itself failing, and from there the vibration took out the rear end, ujoint, and transmission tailshaft bushing.
This took about two years from the original onset of vibration. Transmission died last, as I said, and was probably preventable if I'd replaced the tailshaft bushing/seal sooner.
Good luck; Knowing what I know now, I'd track it down sooner than later. :thumbsup:
