1 - 2 of 2 Posts
Balancer Bolt *SOLVED*
After searching with no luck, here it is.
I need to get the vibration damper/ balancer off my '93 3.8... I have removed the pulley via 4 bolts. Now, only one larger bolt remains that is not budging. I have used massive amounts of penetrating oil, and wedged a prybar to keep it from rotating. With all the force im using, im actually lifting the full block itself. :confused:
Is this bolt reverse threaded? Its stock as far as i know... this joker must have been over-torqued, what do i need to do when I get it off to check if everything is okay... if it ever comes off.
Discussion Starter #2
Finally got it... I shoved a wrench between the "wing" and base of the motor mount on either side so the block wouldnt lift, and with a breaker bar came loose easy.
1 - 2 of 2 Posts
