I have some Steeda pulleys on the way. Is the factory bolt a TTY one and if so do I need a new one or does ARP make a real bolt ?
Thanks
I used the stock one.
The steeda kit came with a longer one to get the pulley on most of the way, then you pull it out and use the stocker to tighten it the rest of teh way.
Thanks ! :thumbsup:
not to hijack.. but does anyone know the PN for the crank bolt? The head on mine got stripped, and I need a new one..
Eleventeenth Gear Poster
F1AZ-6A340-A is the PN I used.
I think its suggested to replace the bolt but not necessary. I replaced mine when I put my Steeda UDs on my NPI motor. When I put them on my PI motor I just used the stock bolt and I've had no problems..
