1 - 20 of 36 Posts
My mechanic said he can do the lower ball joints for about $350, does this sound like a good deal? Also he is extended family so sometimes he takes $50 or so off, but not counting on it just in case.
I know I can replace them my self, but I have very little mechanical experience and don't want to screw things up. The only thing I have worked on my car was stereo stuff, the antenna mast, and the air silencer. And replacing light bulbs in the high mount cause they burn out all the time (I need to look for the bulbs recommend on here that don't over heat or whatever.)
I plan on taking it in this morning and getting it taken care of because I want to go to KC this week. I just wanted a few thoughts.
The LCA's themselves I bought from Advance Auto parts in April of 2007 for $57.48 each plus about $8 in tax; total of about $124 for the parts - They may cost more now; that was two years ago. So, you're looking at about $225 in labor. That's about right for shop work. I recommend the Thunderbird SC lower control arms. They were priced less than the regular LX arms and from what I hear the bushings on them are tighter. Try to get the TRW brand since they were OEM.
I wouldn't recommend just replacing the ball joints without replacing the entire arm. It's just quicker and smarter to replace the whole arm.
You're going to need an alignment after the work is done so figure that into the cost. Either have him include the alignment in the cost or may be cut you a break.
I think the control arms are fine. If you just have the ball joints replaced you don't need an alignment do you? I don't have a ton of money to spend so I'm just doing what needs to be done now. I'm just wondering if $350 seems fair.
Sounds high to me for just the ball joints but they are a bit more involved to replace than just swapping the arm. May be someone else can chime in.
You just have to press the ball joint out right? and the control are involves removing and replacing more stuff, so to me it makes sense that ball joint would be cheaper.
When I replaced my upper and lower control arms, on a 91, it was fairly an easy job. I did what Trunk Monkey did and just bought the whole control arm, It wasn't that hard to replace at all, as long as your got the correct wrenches and sockets for the job, it was basically a piece of cake. If you can do moderate repairs, (swap rear ends, some disassembling here and there on your car, then you should be able to do it and save all that labor money.)
I got a question for Trunk Monkey tho,
on the SC control arms, I need to replace mine that are on my 97 Sport 4.6, what year SC upper and lower control arms would I need? Or would I just need 97 Sport upper and lower control arms..?
Definitely replace the whole lca. Pressing the ball joint out is not easy. Thats what I did on my 95 when I first got it and I had to cut off the top of the ball joint to press it out. It gets way more involved than its worth. Not too mention that extra work being done by going that route is going to be charged at the shops labor rate, which is by no means cheap.
Either one (The '97 Sport or SC) should work fine. Whichever you can get for the best price.
$100 + Cost of parts should be fair. More since he is a mechanic who should have the proper tools, and our Cars are easy to work on.
Yes you should replace the whole LCA, but will require an Alignment.
You can rent a Ball Joint Puller at Autozone for Free(deposit required).
So if you looking for a fast, easy and cheap fix in the short term, do the Ball joint only.
-Maic
I tihnk doing the LCA as a whole will save both time and money.
Ok, so it turns out the $350 was the cost to replace the LCA, and but he didn't think I needed the whole control arm, so he just pressed out the old joints and put new ones in for about $270.
I guess that's not so bad. Did he also replace the LCA bushing?
No he didn't. I'm disappointed because I was hopping getting this fixed would cure my problem of braking and having it pull to the right side. And the car makes a sort of popping sound sometimes through quick turns, and it still does. And now you feel the road better, but in seems to emphasize how loose the steering is. And the alignment is off again, and I just got it aligned a month or two ago.
I bet the problem is your subframe bushings
Discussion Starter #15
Ah! Constant Problems. Oh well, 12 year old car, what can you expect. I'll keep that in mind. Is there any way to straighten out the wheels myself. It drives straight, but the steering wheel itself is just off looking. I have to hold it like I'm gong left, but don't have to turn, that's just it's neutral position. What the normal cost for an alignment. Last on I got was like $65. Is that about right?
I very well understand how you feel at this moment, more after spending that amount of money without the expected result.
On the other side there is lot,s of good Info here and PPL willing to help. For this Money you could have bought the LCA wit Limited Lifetime Warranty,some Tools and an Alignment. On top of that for free you would get the Knowledge Factor(see my sig).
For now, IMO just keep looking forward and write the $270 onto the Account of Life.
-Maic
Discussion Starter #17
Yeah, I wish I could do an alignment myself because now it needs one. Next thing that needs replacing I'll try to do myself. Here my my list of needed things, let me know if you think I could do them and if they should be done in this order and tips on how to.
Vacuum lines because I think one is leaking because it idles rough on start up once in a while, usually when it starts to get warm out side.
Upper ball joints (the control arm of course) because the boots are pretty torn up
Rear diff. has a leaking gasket around the passenger side half shaft
Brakes, mainly the rear rotors
lol, i have no Idea of your basic Mechanical Skills. Cant answear this for You.:D
Cant help you allot here, but you may repost in the proper Forum.
Should be easy, make sure you have / buy a 18mm Ratchet Wrench.
I would pull it and drop it off to have it done correctly
Brakes, mainly the rear rotors Plug and Play
A repair Manual and Search are your best Friends,lol
-Maic
here is a link to repair manuals. Look at the bottom left I always check the manual before starting a new job. Even pros read manuals when they work on stuff they never saw before, they have alldata or mitchell in the shop with every make and model. Trying to guess can become an expensive mistake. The manual also has torque specs so your job can be perfect. Many mechanics do cut corners.
A car I had was serviced at a dealership a few years ago when a relative had it, I have the history. The tech left bump stops off the struts, and killed the rubber strut bushings (the control arm had to be replaced).
Also, it had to be brought back for a broken off strut mount bolt under the hood. Now how does that happen?
If you have a question you search the forums and if you still have issues don't be shy to post.
Labor rates are obnoxious today, just for fun I asked pep boys about replacing 2 tbird control arms, they looked it up for 2 hours each LCA (4 total). They want 100/control arm. over $650 with tax. To replace struts, they wanted 200 for labor and 90 each strut. To replace both sway bar links - $240 parts and labor (this is a real easy job too), and if you are smart the parts should not be more than 50-60 for both).
The rear rotors would be a good job to start practicing....
http://www24.brinkster.com/sdhartney/linc/linc.htm (bottom left)
Discussion Starter #20
How do you flush the power steering fluid? I have searched but can't find instructions on how to do so.
1 - 20 of 36 Posts
