Overkill Fetish Freak
One of the motor mount bolts has a stud that is used to attach the ground wire to. if you look on the pass side you will see the smaller flat ground wire attached to that sides motor mount stud/bolt.
It's the one on the top left corner of GB's pile of nutz & bolts.
-Scott
Dr. FrankenCougie said:
See, I knew you'd need the large size Foreman Grille...
Is that my $19 ARP crank bolt on top of that pile??? Guess I'll ship it back to Jim for core charge... :D
-mike
