Ok havn't found what I was looking for on the battery going in the trunk.. Has any one tried putting a battery where the spare tire is ? I can't use a spare any more because of the brakes on the car ( have to have at least a 18 inch wheel) . If you take the spare out and the jack there is no suport for the cover. So I wanted to see if any one had tried putting a battery in it's place? I was thinking I could put braces in the hole in the trunk for a battery box to slide down in..I have a optima red top. If you think i'm crazy or it won't work let me know.. Thanks
there is no reason you couldnt put it there. Most people just put it over the right tire for traction purposes. You can mount a battery hold down box there for sure. it will most likely stick up further then the spare did though.
Clueless Poster
putting it in the right side of the car also helps even out the weight of the driver. i plan on doing this after my pi head swap or during it while the car is out of commission to make room. for the swap.
Clueless Poster
where is it mark all i see are subs....damn that thing must bump loud. and are there 4 amps in that pic as well?
i have a g31 YT in my trunk. hurricane strapped down in the corner.
