It reallly made that much of a difference?? I really wanted to try this out next weekend. Only trouble I have is where I should run the ground wire.
I had done this years ago to older cars ('70 Charger, '70 Cuda) and those old torsion bar cars responded well, but not as well as the Cougar.
So, I knew it would change the car somewhat based on previous experience. My experience with the Cougar has been that it responds to appropriate mods exceptionally.
Basically, the stock location is as far forward and to the left as it can possibly be, and the battery is about 60 lbs.
So moving that same 60 lbs as far back and to the right as it can possibly be is a pretty dramatic relocation if you think in terms of weight and balance. The arm on the moment is a long one, and the weight is fairly substantial so it is a dramatic physical change.
These cars already handle pretty well, and I will attest to a significant performance handling improvement doing this mod.
There are those opposed to this mod, attributing blame for electrical problems to the battery relocation. My opinion is that they likely used poor technique and chose components poorly. I have had zero battery or charging issues even with the added disconnect switch in the jockey box.
I did this mod as one of the first on this car after we changed the heater core (core is also grounded to the firewall, bonded to the block). I was really happy with the result and it definitely indicated that these cars were given deliberate room for improvement by Ford engineering.
I have continued to mod the car and have been really happy and impressed by the results.
The way the car responded to the battery move inspired more mods to suspension, steering, running gear, engine and drivetrain.
I am glad I did the battery move and full j-mod as first projects. I managed to get good advice, and I think I got a lot of bang for the buck especially with the battery.
You can run your negative conductor to a number of places. I sent a home run to the block and a secondary to the ground post on the subframe right there in the trunk on the right. That ground stud is about 20" from your new battery location.
You may be able to run your primary negative to that secondary ground alone if you run your positive primary directly to the starter. That requires a secondary positive from the fuse box to the battery. I guess that would save some black wire eliminating the run from the neg post to the block.
This is a great time to look at your charge wire (alt to fuse box) and upgrade that.
While you are wiring, I would add a ground wire from the firewall to the block some place. The balance of the harness grounds are very good in these cars, I just made sure they are all connected properly, clean and tight.
For primary conductor I used welding lead, which has a monster cross section and excellent insulation. The only problem I ran into was terminating that heavy guage into automotive #6, #4, #2 spaces. In some cases I bought industrial lugs and modified them to fit. (Like at the fuse panel and the disconnect switch)
I pulled out my seats to do this, pulled back the carpet and pad to get to the wire tray, and took special care fitting the new wire alongside existing when penetrating the firewall.
Good luck!
I look forward to the pics and reading your assessment.
Some people say it's not worth it until you go to the NHRA switch and have a 10 second car...
Which completely ignores the handling aspect.
RD
