Less corrosion? Bling bling?
Unless you are running some high end audio, they really arent needed. I just use the felt pads under each post, and my battery stays clean.
Yes, the little to no corrision is very nice. My Taurus used to corrode so insanely bad (had a "big" system), but with the new gold plated side-post terminals I have had no corrosion at all.
I would say a wise pruchase even if you aren't running a big system or even if you aren't running any system or that matter.
I have factory Ford connectors and have no corrosion. I use the felt pads, and a little grease, and never have had a problem. I think most of the corrosion is from not having a good connection anyways.
