i was poking around my engine the other day because the car was feeling slightly sluggish. well i found my spark plugs were a little loose. well i took them out to look at them because they were already loose:rolleyes: and noticed that im burning my plugs... i checked the back of the haynes manual to compare the spark plugs and they were definitely hot... neways i have the MSD coil pack and think that is probably the culprit.. i never updated my wires or plugs so i am in the market, however comma. i want to find a set that has the least resistance. i know that they base the quality of wire on the ohms per foot, and ive found that the accel universals 300+ have a 150ohm per foot... thats the best ive found...
so i wanted to start a feeler as to the best plugs and wiresthat you guys have and think is the best for split port set up's and N/A 3.8L's..
also if anyone is running the iridium spark plugs id like some feedback on the quality..
thanks,
tyler
Confirmed V6 Nut
I've got the FRPP blue 9mm wires (For "Mudstain" V6). I'm quite happy with them.
