What are your goals/plans?
"Best tranny" is subjective, we can't tell you what's best without knowing the application.
From what I've read on the subject (not an expert here). Grab an 01+ 4r70w and either beef it up, or leave it alone. Either way it's better than what's in there now.
You'll probably want to have an 03+ trans built to J-spec (03+ had hardened gears).
Yep late 03 build tag or 04+ model year. They require a few internals swapped but come with hardened parts. For example if you don't want to use a speedo cal device you'll need a 96/97 bird output shaft.
