yeah so my car was misfiring on #7 and #8 cylinder, I took the spakr plugs out only to find oil all over them. This is bad. What exactly should I do here? Would it be more expensive to fix that or just have a new PI engine put in? thoughts?
Depends on where the oil fouling is coming from.
It it's the rings/pistons, I'd recommend the new engine.
If it's the guides/valve seals, I'd recommend repairing it.
Those are always tough decisions: repair or replace! :D
And it depends if you're doing the work yourself, or farming it out to a shop.
Just my thoughts and I'm sure others on here will have more suggestions.
Good luck. :thumbsup:
I had had similar prob, (#7&#8)and cleaned up the plugs, and was ready to do a valve seal job, but the problem just went away... the answer was that somehow oil/water got into those wells, coated the plugs enuff to cause misfire , and foul the plugs due misfire.... if cleaning the plugs/wells doesnt work, go for the valve seals if a compression test doesnt reveal a ring problem( Worked for me) good luck
5.4L '95LX, awaiting partz and blower install
