Baddest N/A NPI in Canada
Triangle Speed Shop
http://www.trianglespeedshop.com will give you their contact number. That is the only place to get them if you want them properly spec'd and made of the right material...
TGJ thanks how much$$$ would they run for a Cobra Oil Pump, I know I should of went with the stock pump but Im stuck with it now.
Best bet is to contact them. I am pretty sure the price has changed since I have had mine and I am not going to venture a guess.
High-Mileage 4.6L Thrasher
Wheres a good place to get billet oil pump gears for a good price?
You must be careful in purchasing based on a "good price". As for an item like this,you want a part that will not break,not the best deal you can find. Call Daniel or Craig at Triangle Speed Shop-they will get you a good product that you can trust to work properly and not fail.
JL
