Can SomeOne Help Me w/ this!!??
plzz..
It Was Bouncing At First, then once I hit 45 It went dead..
SomeOne plz Help A fellow T-Bird Owner..
first you need to find out WHY very simple
put the bootie end of the bird on jackstand so the wheels spin freely
crawl underneath with a dmm and tap into the vss wires
get someone to put the car in drive for you and see if your getting a signal
if your not getting nothing than the sensor gear probably got eaten
if you are getting something then its time to trace it
Thanks.. Im guessing Its the Tranny sensor..
runs about 40 Bucks..
Egh..
Whats An DMM n' where r the VSS wires??
I think he means DMM = digital multimeter and VSS = vehicle speed sensor.
It's on the side of the tranny, and has the gear you change out to match the gears you have...
If you had the 23 tooth gear, it's bad now. :)
Soo.. I have to replace a gear In my tranny???
GREAT!!!!
^ this Is 4sho My Fix!!!!!!!!!????
