Hey, new to the forums and TCCoA.
Basically whats going on is that im getting a code: 23 from my air bag light. Now i googled it to see what it ment. Basically what i found was this: "Okay, if I'm understanding you correctly, there is two long flashes and three short flashes. If this is the case, then the SRS Air Bag system has detected a fault and stored a DTC. In this case, code 23. In this case DTC 23, or B1923, is "Memory Clear Circuit Improperly Grounded". There are two possibilities for this code. One is a bad or broken ground connection or a bad Air Bag Control Module.
If you are saying the horn and cruise control do not work also, then it is a good possibility the Clockspring Assembly/Spiral Cable in the steering wheel is bad.
The air bag will not deploy while driving. In fact this code indicates the air bag system is disabled. If you decide to have it repaired, you should do it before your next accident."
So any suggestions on replacing the Clockspring Assembly/Spiral Cable. Basically the horn doesnt work and the air bag light. Have yet to try cruise control.
Im thinking i may have broken something or nearly broke something while taking dash out to replace heater core, fun.
Well thanks in advance
