I need to flush out the block. The coolant is very dark green. If I open the drain on the radiator, run the engine and use a garden hose to flush out the radiator, will I eventually flush out the block? Then refill with 100% anti freeze and water.
Refrigerator Raider Hater
Prestone makes a flush and fill kit. Just get some extra hose you don't have to cut your stock hose.
the perstone flush and fill kit works great. I cut my hose and just put the cap on it, no leaks or anything. Took a whole 5 mins!! Def. Worth it
