I keep blowing the 60A fuse to my radiator fan (about every two weeks). My first thought is it is a short in the wires. Any easy way to check this and replace them? Could it be the Coolant temperture sending unit, temperture sensor or EEC-IV system? Any other thoughts? The fan runs (when the fuse is good) and the water pump does not leak. Thanks
Confirmed V6 Nut
Integrated Relay Control Module. It is behind your right headlight. If the little relay is going flaky there that controls the fan, go to the junk yard and get another one. Cheaper that way.
