1 - 2 of 2 Posts
My XType has 5-108 bolt pattern just like the SC
I looked up rims for both the tbird and x type and found this
SC +42mm offset, backspacing 5.90 bolt pattern 5-108
Xtype +45mm offset. backspacing 6.02 bolt pattern 5-108
these were just two rims I picked at random from tirerack
I wonder if the tbird rims would fit
Basically the concept is I want to get my rims repaired and if these worked it would be awesome
yes the will be fine chris.
lower the offset # more they stick out. higher the offset # more in the wheel well they go.
backspace shouldn't be to far off. bolt pattern should be the same. unless you wanna re-drill the holes larger or doa hub swap..which becomes pretty pricey
1 - 2 of 2 Posts
