i know the Bosch 4+ will run $6 each.......how much do the Motorcraft Double Platinums run for? either one better in anyway compared to the other for a 4.6L 97 XR7?
also, i noticed that the rear wheels are "sagging" a bit outwards from the bottom.........like slanted a bit if you know what i mean i'm assuming its because of the independent rear suspension......how does this get fixed and how much does it run?
thanks
Not heard good things about bosch. Just buy the motorcrafts. Cheaper and better quality.
As for the suspension, i dunno, rear alingment? :D
thanks
That would be negative camber and a four wheel alignment runs around $55 here.
