Hi, before I go freaking myself out trying to get new parts for a rotted brake line, does anyone know what the dimensions are for the brake line -- metal -- for the front left (driver's side) line on a 97 LX 4.6? I'm guessing 3/16", and maybe 12-14 inches long, and probably double-flared, but I could be way off. I've got to tackle this soon, obviously can't drive anywhere until I get it fixed, and I'm trying to get organized here for the job. Any sage information would be much appreciated!
Yes, it should be 3/16 and use double flairs.
If you plan on doing brake lines both now and in the future; I would recommend buying line in bulk coils, getting a handful of fittings, and getting a basic flair tool. Being able to make your own lines at whatever length you need is pretty handy.
Discussion Starter · #3 ·
Thanks, Thunderstruck. Good advice. That helps ease my mind. Not fun to see the brake pedal bottom out. I'll get a double-flare tool; I've used a single flare tool before and done well after some trial and error. Kind of tricky stuff though.
