I need to know what is on the driver side of the car, in front of the front wheel. If you pull down the shield you can see a black box, and what appears to be a pump.
I don't know what it is, and Haynes manual doesn't say anything about it, but it's making a grinding noise all the time.
If I start the car and attempt to press in the brake pedal, I get the grinding noise through the brake pedal that rattles the car. Barely pressing in the pedal will even lock the breaks up.
