1 - 2 of 2 Posts
I'm thinking about replacing my front rotors with Raybestos PG Plus rotors. These are a composite rotor made from two stainless steel discs. Anyone out there that has these? I have the sport option with the bigger front brakes. I can get the pair for around $115.00.
Also many thanks to Chris Conners from Woodbridge VA for recommending a reliable and reasonably priced mechanic to replace an engine in my sons car. Son is attending college in the area.
Are they cross drilled? If not, I recommend cross drilled rotors. For $110 c-drilled I may be interested in joining in on that deal.
Contrary to what some say I have had c-drilled for years and they have never cracked on me and they can be turned.
Basically you have the same front rotors as the Mark VIII.
I have found that KVR rotors are reliable. But I have been thinking about getting some Powerstop rotors from Summit for my 97. Here are the part numbers:
Left Front# PWR-AR-8149L
Right Front# PWR-AR-8149R
I think my front brakes will be in need of repair soon. I plan to do something in the spring.
1 - 2 of 2 Posts
