I Have a 1990 SC with Auto. Tha problem is with the brakes. I've read you can install a master, and boost from a Crown Vic. Can someone please tell me what year I need, and how much of a job is it. Thank you
I want to say a 92 vic but go over to sccoa and do a search to make sure
i did the swap and used a 90 thunderdird booster and master. hooked the 2 frontlines and 1 rear line and put a bleader in the 4th hole. i did not use a porpshing valve for the rear. because i like the feel of a little more rear brakes. cost $250 to do the swap. the thread at the sccoa said to use a thunderbird booster and a vic master but you have to find a longer push rod to make it work:rolleyes: thunder bird master works great. i tested it verry well (130 to 0) as fast as i can:D with no problem. $250 includs every thing from parts to fluid. just pull the fuses for the abs and the antilock light will go off. i got new booster and master and used resvoir from junk yard. allso saved a few bucks by geting cores there too.
