1 - 2 of 2 Posts
How do I check these things? I was told my terriable gasmilage can be cause by these...
searchy searchy.
http://forums.tccoa.com/showthread.php?s=&threadid=3741&highlight=clogged+injector
Lastly, is your speedometer on the car accurate? If its not than the odometer that you are probably using to calculate fuel mileage would give you incorrect calculations.
Also you have 327's, you will probably get a hare less mpg than the 308 guys. Depending on your driving style, if the car is a stock tune than I would say you aren't too far off of what you should be getting. My 95 with the stock tune and stock everything got about 16-17 around town.
JH
1 - 2 of 2 Posts
