Status
Not open for further replies.
1 - 1 of 2 Posts
Bulletins for 1989 Ford Thunderbird V6-232 3.8L SC
Safety Recalls
TSB Number Issue Date TSB Title
  1. 95S28 NOV 95 Safety Recall 95S28 - Ignition Switch Replacement
  2. 92S52 SEP 92 Recall Safety Front Safety Belt and Retractor
  3. 91S32 MAY 91 Recall Safety Seat Belt Assembly Replacement
  4. 89S64S1 SEP 89 Recall - Rear Suspension Knuckles
  5. 89S63 JUN 89 Safety Recall 89S63 Extended Brake Pedal Travel
  6. 89S64 JUN 89 Safety Recall 89S64 Rear Suspension Knuckles
Emissions Recalls
  1. 92E22 APR 92 Recall 92E22 - Disconnected Fuel Vapor Hoses
  2. RECALL92E22 MAR 92 Emissions Recall 92E22 Fuel Vapor Hoses Disconnected
General Recalls
  1. 93B31 DEC 93 Throttle Body Lever Grommet - Recall 93B31
  2. 92B11 OCT 92 Recall 92B11 - Front Disc Roughness, Brakes Shudder
  3. M71901001 OCT 90 Program M71 - Front Disc Brakes Vibrate No Charge Repair
Service Bulletins
  1. 99-8-16 MAY 99 Motor Oil-SAE 5W-30 Viscosity Grade Recommendation
  2. 99-6-3 APR 99 Wire Splicing And Wire Harness Terminal Repair Kit
  3. 98-26-2 JAN 99 Tips To Resolve Volatility Related Driveability Concerns
  4. 98-18-14 SEP 98 A/C-Water Drips On Floor-High Blower/MAX-NORMAL A/C Mode
  5. 98-17-1 SEP 98 Seat-Leather Cleaning Procedure-Service Tip
  6. 98-12-5 JUN 98 A/C-Filtering Refrigerant After Compressor Replacement
  7. 98-12-8 JUN 98 A/C-Identifying Non-Ford Approved Refrigerants
  8. 98-8-8 APR 98 Automatic Transmission Fluid Usage Charts
  9. 98-7-4 APR 98 Oil Leaks-New Silicone Gasket And Sealant
  10. 98-5A-13 MAR 98 Brakes-New Application-Silicone Compound/Grease
  11. 98-5A-4 MAR 98 Preventing Brake Vibration, Lug Nut Torque Procedures
  12. 98-4-8 MAR 98 Air Conditioning, R-12 to R-134A Retrofit Kit
  13. 98-5-2 MAR 98 Tire Company Telephone Numbers - Customer Assistance
  14. 97-25-5 DEC 97 Chirping/Squeaking From Blower Motor At Low Speeds
  15. 97811 APR 97 Whining/Howling Noise from Rear Axle
  16. 962612 DEC 96 Torque Converter Cleaning and Replacement Guidelines
  17. 96246 NOV 96 Electrical Diode Identification and Replacement
  18. 96249 NOV 96 Service Tip - Torque Converter Leak Test Procedure
  19. 96221 OCT 96 Fog/Film on Windshield/Interior Glass
  20. 96214 OCT 96 Alternator Discharge - Harness Connector Damaged
  21. 961710 AUG 96 Use of R-12 Refrigerant Substitutes - Service Tip
  22. 96164 JUL 96 Ford's Position On Propylene Glycol Coolant
  23. 96156 JUL 96 A/C System Service TSB List
  24. 96129 JUN 96 Chatter During Turns After Extended Highway Driving
  25. 96107 MAY 96 California Reformulated Gasoline (CARFG) Service Tip
  26. 9611 JAN 96 New Torque Specs For Installing New Design Tie Rods
  27. 95243 DEC 95 Rocker Arm Squeak, Chirp or Knock Noise
  28. 95233 NOV 95 Air Conditioning - Water Drips On Floor
  29. 95203 OCT 95 Groaning Noise From Power Windows
  30. 95184 SEP 95 Air Conditioning - Ford Approved Flushing
  31. 95182 SEP 95 Recycled Engine Coolant - Service Tips
  32. 951610 AUG 95 New Rotunda Fluid Changer - Service Tip
  33. 95132 JUL 95 Temperature Gauge Reads Low/Erratic
  34. 95121 JUN 95 Windshield,Urethane Mounted, Material Usage Tip
  35. 9582 APR 95 Wiper Motor - Upgraded Service Kits
  36. 9562 MAR 95 Brakes - Roughness During Brake Application
  37. 9561 MAR 95 Paint - Iron Particle Removal
  38. 9552 MAR 95 Windshield Sealer Drips on Interior Trim
  39. 9522 JAN 95 Air Conditioning O-Ring Removal - Service Tip
  40. ATRATB277 JAN 95 Harsh 4-3 Kickdown - Valve Body Repair
  41. 94255 DEC 94 Anti-Theft Protection - Recap of TSB's - Service Tips
  42. 94252 DEC 94 Brake Rotor Machining Equipment and Warranty Information
  43. 94234 NOV 94 Paint Preparation Procedure And MSDS Information
  44. 94201 OCT 94 Front Seat Track Covers - Come Off When Moved Rearward
  45. 94-14-3 JUL 94 R-12 Refrigerant Substitutes
  46. 94114 JUN 94 A/C - Evaporator Core and Case Assembly Application
  47. 941112 JUN 94 Rear Axle Lubricant Leakage Through Cover Vent/Hose
  48. 9489 APR 94 Fuel Injector Cleaner - Parts and Service Tips
  49. 94212 JAN 94 A/C - Water Leaks From the Floor Ducts
  50. 9429 JAN 94 Air Conditioning - Poor Performance
  51. 9424 JAN 94 Instrument Panel - Cluster Finish Panel Loose
  52. 9415 JAN 94 Service Parts Return of Obsolete Fuel Pressure Regulator
  53. ATRATB254 JAN 94 Cooler Return Line - Filter Installation
  54. 93261 DEC 93 Heated Backlite Inoperative
  55. 932612 DEC 93 Return of Obsolete Starter Solenoids and Starter Drives
  56. 93252 DEC 93 A/C Evaporator Tube Worn By Canister Purge Hose
  57. 93241 NOV 93 Bumper Cover Repair Materials
  58. 932410 NOV 93 Instrument Cluster Warning Lights
  59. 93248 NOV 93 Rough Idle/Hesitation/ Poor Heater Output
  60. 932318 NOV 93 AOD Transmission - Diagnostic Information
  61. 93236 NOV 93 EGO Sensors - Silicone Contamination
  62. 932314 NOV 93 Engine Gasket Surface Cleaning Procedures
  63. 93231 NOV 93 Moon Roof - Wind Noise When Fully Open
  64. 93226 OCT 93 Air Conditioning - Return of Obsolete Filter Kits
  65. 93211 OCT 93 Glass - Iridescence or Mottling In Tempered Glass
  66. 93206 SEP 93 Air Conditioning - Use of Correct Fluorescent Tracer DYE
  67. 9319B6 SEP 93 Body Collision Repair Manual Revised
  68. 931511 JUL 93 Labor Times Standards
  69. 93132 JUN 93 Tie Rod End (Inner) - Replacement Procedure
  70. 93126 JUN 93 Engine Stalls/Hesitates/Long Cranking Times
  71. 93129 JUN 93 Speedometer - Service Replacements With Pre-Set Mileage
  72. 9384 APR 93 Exterior Clearcoat May Crack, Erode or Peel Off
  73. 9365 MAR 93 A/C Coupling Cleaning Procedures/New O-Ring Available
  74. 9363 MAR 93 Rear Brake Pulsation
  75. 93312 FEB 93 Moan or Slow Beating Noise From Axle While Driving 55MPH
  76. 9322 JAN 93 Power Door Lock Inoperative
  77. 93110 JAN 93 Cooling System - Proper Fluid Concentration
  78. 92252 DEC 92 Engine Repair Tips to Avoid Potential Engine Damage
  79. 92246 NOV 92 FX15 A/C Compressor - Oil Recovery & Measuring Procedure
  80. 92211 OCT 92 False Security Alarm - Bend Tank Lock Switch TAB
  81. 92205 SEP 92 A/C Clutch Slip At High Ambient Temperature
  82. 9218B3 SEP 92 Active Suspension Diagnostic Test A1, Code 15 and 25
  83. 92184 AUG 92 A/C FX-15 Compressor Oil Recovery & Measuring Procedures
  84. 92174 AUG 92 Moan From A/C Compressor At Idle to 1,500RPM
  85. 9211B1 JUN 92 Revised Procedure For Starter Motor Brushes Replacement
  86. 92128 JUN 92 A/C Condensation Enters Into Passenger Compartment
  87. 92124 JUN 92 Brakes-Rotor-Replacement Service Tips
  88. 92112 MAY 92 Front Door Glass May Separate From the Glass Bracket
  89. 9258 FEB 92 A/C FX-15 Compressor Clutch Shaft and Hub Assembly
  90. 9243 FEB 92 Brakes - Roughness, Pulsation or Steering Wheel Shake
  91. 9232 JAN 92 High Efforts Depressing the Horn Pad to Sound the Horn
  92. 9233 JAN 92 Oil Pan Front Cover Gasket Leaks Oil
  93. 9223 JAN 92 Power Seat Operation Slow, Stalled and/or Inoperative
  94. ATRATB088 JAN 92 Ford Electronic Engine Control Trouble Codes
  95. ATRATB089 JAN 92 Ford Service Codes 1983-1990
  96. 91257 DEC 91 Hard Cold Starts, Hesitation, Stalls On Initial Start-Up
  97. 91247 NOV 91 Check For Ignition Pinpoint Tests - Service Tips
  98. ATRATB078 NOV 91 How To Use A Pressure Gauge - Automatic Trans.
  99. 91225 OCT 91 New Refrigerant O-Rings (Green Color)
  100. 91193 SEP 91 New Method of Fuel Injector Cleaning
  101. 91195 SEP 91 Power Window Regulator Counterbalance Spring
  102. 91181 SEP 91 Exterior Paint Repair Procedures
  103. 91188 SEP 91 Radio Sound Distortion From Speakers
  104. 91177 AUG 91 Hissing Noise From the Tape Player
  105. 911612 AUG 91 AOD Increased Shift Times
  106. 91155 JUL 91 "Refrigerator Type Smell" or Odor From A/C System
  107. 91151 JUL 91 Water Leaks On Passenger Side Front Floor
  108. ATRATB063 JUL 91 Direct Clutch Failure - Excessive Case Bore Wear
  109. 91136 JUN 91 Exhaust Moan or Vibration Occur At About 2100 RPM
  110. 91134 JUN 91 Fuel Gauge Intermittently Shows Increase In Fuel Level
  111. 9111B5 JUN 91 IDM and Spark Timing Diagnosis Manual Revision
  112. 9111B6 JUN 91 Revised Octane Adjust Shorting Bar Procedures
  113. 9111B11 JUN 91 Revised Supercharger Diagnostic Procedures
  114. 911114 MAY 91 Harsh or Rough Transmission Shifts
  115. 91111 MAY 91 Windnoise From Standard Antenna
  116. 91108 MAY 91 Battery In A Low State of Charge Causing A No Crank Condition
  117. 911010 MAY 91 Battery Test Procedure
  118. 911011 MAY 91 Loctite 510 Only From Loctite Distributors
  119. 91101 MAY 91 Service Part Information For Passive Restraint
  120. 9195 MAY 91 Driveability Problems Caused By EEC IV Processor
  121. 9192 MAY 91 Paint Blistering or Peeling Off Bumper Covers
  122. 9197 MAY 91 Service Tips On Usage of R-12
  123. 9184 APR 91 Unacceptable Door Latches
  124. 91813 APR 91 Use of Unleaded Gasolines to Avoid Driveability Problem
  125. 9171 APR 91 Damaged Passive Track Dust Seals
  126. 9175 APR 91 Processors Damage From Arc Welding
  127. 915B13 MAR 91 Refrigerant System Leak Manual Update
  128. 9151 MAR 91 Electric Rear Window Defroster Inoperative
  129. 9154 MAR 91 Wiper Arms Adjustment Procedure
  130. ATRATB045 MAR 91 No 4th, Late 4th, Falls Out Of 4th
  131. 9128 JAN 91 Analog Speedometer Inaccurate At High Speeds
  132. 9118 JAN 91 Torque Spec. For New Graphite Intake Manifold Gasket
  133. 9025B3 DEC 90 Code 14 Diagnostics, Manual Correction
  134. 9025B6 DEC 90 Horn/Speed Control Switch Assembly Manual Revision
  135. 9025B10 DEC 90 Instrument Cluster Schematic Revised
  136. 90261 DEC 90 Chattering From Motorized Passive Restraint System
  137. 90267 DEC 90 Poor Radio Reception
  138. 902510 DEC 90 High Effort When Depressing Horn
  139. 902512 DEC 90 Speed Control Diagnostic Tips
  140. 90246 NOV 90 Parking Brake Release Button May Separate From Handle
  141. 90239 NOV 90 Dim or Blank Display From Instrument Cluster
  142. 902310 NOV 90 Temp. Gauge Not Functioning Correctly, Supercharged Engines
  143. 90229 OCT 90 Authorized Audio Systems Service Centers
  144. 90226 OCT 90 Intermittent Brake Squeal
  145. 90211 OCT 90 Safety Belt Tongue Service Kit
  146. ATRATB028 OCT 90 Engine Testing With A Vacuum Gauge - Auto Trans.
  147. 90194 SEP 90 Door Handles May Pinch Finger(S)
  148. 90195 SEP 90 Inoperative, Sticking or Slow Seat Track
  149. 90193 SEP 90 Service Kit For Front Safety Belt Outboard Tongue
  150. 90199 SEP 90 Use A Manual Torque Wrench to Tighten Wheel Nuts
  151. 9018B3 SEP 90 Pinpoint Test S, EGR Vacuum, Manual Revision
  152. 9018B7 SEP 90 Rotunda EVO System Tester Revised Information
  153. 9018B5 SEP 90 Speed Control, Manual Revision
  154. 9018B1 SEP 90 Speed Sensor Resistance Reading Manual Revision
  155. 9018B8 SEP 90 Split Fold-Down Rear Seat Manual Update
  156. 9018A1 SEP 90 Summary of Driveability TSB's
  157. 9018B2 SEP 90 Timing Procedure Manual Update
  158. 90183 AUG 90 Sticking Fuel Pump Relay
  159. 90153 JUL 90 Lower Body Stone Protection, Repair Procedure
  160. 90132 JUN 90 Wheel Balance Weights
  161. 9012B10 JUN 90 Fuel Injector Removal Procedure, Manual Revision
  162. 901210 JUN 90 A "Clicking" or "Buzzing" Noise From the Speed Control
  163. 90122 JUN 90 Loose Instrument Finish Panel
  164. 90116 MAY 90 Disconnect the Battery Ground Cable If Arc Welding
  165. 906B12 MAR 90 AOD Automatic Transmission Disassembly and Assembly
  166. 906B37 MAR 90 Conventional Tachometer - Manual Revision
  167. 906B35 MAR 90 Incorrect Balance Shaft Drive Gear - Manual Revision
  168. 906B32 MAR 90 Intercooler - Manual Revision
  169. 906B33 MAR 90 Supercharged and Base Engines Titles Revised
  170. 906B2 MAR 90 Suspension Specification, Manual Revision
  171. 9068 MAR 90 Sound From Rear Speakers May Be Distorted
  172. MEMO030190 MAR 90 VECI Replacement Decal Index, Model year 1989
  173. 9046 FEB 90 Fuse # 18, Wire Assembly 14A488, Splice 229, May Short
  174. 90410 FEB 90 Recycled Engine Coolant Not Authorized
  175. ATRATB9002006 FEB 90 Automatic Transmission Fluid
  176. 9031 JAN 90 Loose or Broken Hood Lift Retainers
  177. 9038 JAN 90 VMM Oil Change Indicator Reset Procedure
  178. MEMO900125 JAN 90 Return of 11 Blade Fan Assembly
  179. 9012 JAN 90 Door Glass Run May Split or Crack
  180. 9018 JAN 90 Ford RTV Sealer Shelf Life
  181. 8925B1 DEC 89 A/C & Heater Odor Treatment
  182. 8925A1 DEC 89 New Service Procedure For Loose/Broken Hood Lift
  183. 8925A8 DEC 89 Pinpoint Test Step KE15 - Revised
  184. 8925A4 DEC 89 Test Step TA3, Check Fuse - Revised
  185. 89251 DEC 89 Ignition Key Hard to Remove
  186. 89257 DEC 89 Propane Testing to Check For Air Leaks Supercharged ENG.
  187. RSB89170 NOV 89 Defective Fuel Pump and Sender Assys
  188. 89236 NOV 89 "Buzzing" At Idle or "Grunting" During Tip-In
  189. 89237 NOV 89 AOD Transmission Gasket Changes
  190. 89222 NOV 89 A/C Compressor Shaft Seal Leaks
  191. 89206 OCT 89 Instrument Cluster or Radio Failures Caused By A Bad "Memory" F
  192. ATRATB8930 OCT 89 Automatic Transmission Math Part 2
  193. 89192 SEP 89 Ignition Key Warning Switch-Replacement Procedure
  194. 89197 SEP 89 Intermittent Sound From Front or Rear Speakers
  195. 89195 SEP 89 Wire Harness Terminal and Connector Service Kit
  196. 8918A9 SEP 89 EVP Sensor Manual Revision
  197. 8918A10 SEP 89 Key On Engine Off Self-Test Procedure Manual Revision
  198. 8918A5 SEP 89 Manual Revision On Transmission Removal and Installation Proced
  199. 8918A1 SEP 89 Manual Updates On 1989 Section 36-38 Heated Backlite Grid
  200. ATRATB8927 SEP 89 20 Steps To successful Auto Transmission Repair
  201. 8918A3 SEP 89 Manual Revision On Outside Mirror Glass Replacement Procedures
  202. 891713 AUG 89 Air Conditioning - Service Replacement Kits
  203. 89173 AUG 89 Aluminum Wheel - Air Leaks
  204. 89174 AUG 89 Removal of Bright Green Colored Sticker
  205. 89166 AUG 89 Breakout Box and Monitor Box Connections
  206. 891611 AUG 89 Interference On AM Radio Band
  207. 89161 AUG 89 Outside Mirror Replacement Manual Correction
  208. ATRATB8923 AUG 89 Automatic Transmission Math Formulas
  209. 89155 JUL 89 A/C-Heater System-Slow Warm-Up or Insufficient Heat
  210. 89157 JUL 89 Locked In Compact Disc Mode
  211. 89153 JUL 89 Rotunda Injector Tester/Cleaner
  212. 89152 JUL 89 Trunk-Lock-Bent Cylinder TAB Falsely Activates Alarm
  213. 891410 JUL 89 Air Conditioning-Clutch Pressure Cycling Switch Diagnostic Proc
  214. 891412 JUL 89 Controls Lock Up When Radio Is In Tape Mode
  215. 89146 JUL 89 Fuel Tank Sending Unit-Connector Replacement
  216. 891411 JUL 89 Fuel-Gauge-Occasionally Sticks In "Full" Position
  217. 89149 JUL 89 Heater Core-Core Leak Test Procedure
  218. 89147 JUL 89 Throttle Position Sensor Mounting Screws Hard to Remove
  219. 89141 JUL 89 Warning Lamp Stays "On" When Safety Belt Is Buckled
  220. ATRATB8922 JUL 89 Governor Pressure Leaks
  221. 89138 JUN 89 Air By-Pass Valvecleaning and Replacement Service Tips
  222. 89133 JUN 89 Cosmetic Damage From Airborn Materials
  223. 89139 JUN 89 Transmission PRNDL Bulb Socket Melted
  224. 8912A17 JUN 89 Engine Emissions Diagnosis Manual Revision
  225. 8912A16 JUN 89 Manual Revisions On M5R2 & AOD Transmission
  226. 8912A25 JUN 89 Manual Specification Corrections
  227. 8912289614 JUN 89 Adhesives and Sealants Usage
  228. 8912189614 JUN 89 Aftermarket Supplier Color Chart
  229. 89114 JUN 89 Door Weatherstrip Comes Loose
  230. ATRATB8916 JUN 89 Rear Planet Failure, Due To Lack Of Lubrication
  231. 89113 JUN 89 Revised Procedure For Installing Urethane Adhesive Held Windshi
  232. TECGLOS JUN 89 Technician's Glossary (Emission Related)
  233. TECGLOS MAY 89 Fuel System Glossary
  234. 89915 MAY 89 AOD New Design Compontents
  235. 89910 MAY 89 Normal Oil Consumption In Today's Engines
  236. TECGLOS MAY 89 Technician's Glossary (Electrical/Electronic and Fuel Induction
  237. 8987 APR 89 Noise Heard In Passenger Compartment, Fuel Pump
  238. 8983 APR 89 Optional EEC-IV Monitor Requires Update Kit
  239. 8979 APR 89 Rear Axle Fill Plug Hard to Remove
  240. ATRATB8913 APR 89 No Manual Low
  241. 895A15 MAR 89 Autolamps/Delayed Exit - Vacuum Troubleshooting Manual Correcti
  242. 895A13 MAR 89 EEC IV Distributorless Ignition System Shop Manual Revisions
  243. 895A16 MAR 89 Fuel Tank Removal and Installation Procedures Manual Correction
  244. 8964 MAR 89 Fuel Tank Replacement Service Tips
  245. 8966 MAR 89 No Start Condition or Accessories Do Not Work Loose Wire
  246. 895A17 MAR 89 Permanent Magnet Starter Motor Manual Supplemental Information
  247. 895A6 MAR 89 Pinpoint Test "DF" - MAP Sensor Manual Correction
  248. 895A7 MAR 89 Timing Procedure and Diagnostics Manual Correction
  249. ATRASIL8910 MAR 89 3-4 Accumulator Change
  250. ATRASIL8911 MAR 89 Valve Body Gaskets
  251. 8946 FEB 89 3/4 Shift Accumulator No Longer Required
  252. 8934 FEB 89 Abnormal Speed Control Operation In High Ambient Temperatures
  253. 8921 JAN 89 Crossmember - Center Support Bracket Installation
  254. 89211 JAN 89 New Main Control Separator Plate Gaskets
  255. 8927 JAN 89 Speedometer/Odometer Readings
  256. 89112 JAN 89 "MAP" and "BAP" Sensor Application Chart
  257. 89-1-10 JAN 89 EEC IV-Octane Adjust Shorting Bar-Shop Manual Correction
  258. 88266 DEC 88 EGR Transducer Sensor Condensation
  259. 88265 DEC 88 Pinpoint Tests A, N and P Manual Correction
  260. 88251 DEC 88 Passive Restraint System Manual Revision
  261. MEMO89 DEC 88 Initial Vehicle Emission Control Index (VECI) 1989
  262. 88233 NOV 88 Exterior Roof Ditch Moulding Shop Manual Update
  263. 882313 NOV 88 Longer Than Normal Engine Cranking Time
  264. 88225 OCT 88 Paint Chips While Prying Off Center Ornament
  265. 88207 SEP 88 Output Shaft Snap Ring and Application
  266. ATRATB8840 SEP 88 Failure In Rear Of Transmission - Lack Of Lubrication
  267. ATRATB8839 SEP 88 Kills Engine In Reverse And/Or Forward Gears
  268. 881615 AUG 88 Pre-Delivery Service Record - New Items For 1989 Model Year
  269. 88154 JUL 88 Theft Prevention Parts Identification Number
  270. 88133 JUN 88 Protection From Static Electricity
  271. ATRATB8825 JUN 88 Harsh 1-2 Upshift, Or Slide Bump 1-2 Upshift
  272. ATRATB8820 MAY 88 Loss Of Governor Pressure Through The Valve Body
  273. 8899042788 APR 88 Vehicle Storage - Maintenance Tips
  274. ATRATB8810 FEB 88 Burned Overdrive Band, Or End Play After Rebuild
  275. ATRATB8754 SEP 87 All Automatics - Front Bushing Wear
  276. ATRATB8748 AUG 87 Metal Sealing Rings - Automatic Transmissions
ALLDATA has obtained this information from the original
equipment manufacturers and others and ALLDATA believes it to be reliable.
However, ALLDATA makes no warranty regarding the information, express or
implied, and accepts no responsibility for the accurancy or completeness
of the information provided.
In no event shall ALLDATA be liable for any damages arising from the use or
misuse of this information, including, but not limited to, any direct, indirect,
incidental, special or consequential damages arising out of the use or inability
to use this information.
Copyright © 1996-2000 ALLDATA
LLC
. All Rights Reserved.
1 - 1 of 2 Posts
Status
