Status
Not open for further replies.
1 - 1 of 2 Posts
Bulletins for 1990 Ford Thunderbird V6-232 3.8L
Safety Recalls
TSB Number Issue Date TSB Title
  1. 95S28 NOV 95 Safety Recall 95S28 - Ignition Switch Replacement
  2. 91S34 MAY 91 Recall 91S34 Loose Windshield Wiper Motor Attaching Nuts
  3. 90S03 MAR 90 Recall 90S03 Starter Cable Replacement
General Recalls
  1. 93B31 DEC 93 Throttle Body Lever Grommet - Recall 93B31
  2. 92B11 OCT 92 Recall 92B11 - Front Disc Roughness, Brakes Shudder
  3. M71901001 OCT 90 Program M71 - Front Disc Brakes Vibrate No Charge Repair
Service Bulletins
  1. 99-8-16 MAY 99 Motor Oil-SAE 5W-30 Viscosity Grade Recommendation
  2. 99-6-3 APR 99 Wire Splicing And Wire Harness Terminal Repair Kit
  3. 98-26-2 JAN 99 Tips To Resolve Volatility Related Driveability Concerns
  4. 98-23-10 NOV 98 Mass Air Flow Sensor Contamination-Service Tip
  5. 98-18-14 SEP 98 A/C-Water Drips On Floor-High Blower/MAX-NORMAL A/C Mode
  6. 98-17-1 SEP 98 Seat-Leather Cleaning Procedure-Service Tip
  7. 98-12-5 JUN 98 A/C-Filtering Refrigerant After Compressor Replacement
  8. 98-12-8 JUN 98 A/C-Identifying Non-Ford Approved Refrigerants
  9. 98-8-8 APR 98 Automatic Transmission Fluid Usage Charts
  10. 98-7-4 APR 98 Oil Leaks-New Silicone Gasket And Sealant
  11. 98-7-3 APR 98 Whining/Buzzing Noise Through Radio Speaker
  12. 98-5A-13 MAR 98 Brakes-New Application-Silicone Compound/Grease
  13. 98-5A-4 MAR 98 Preventing Brake Vibration, Lug Nut Torque Procedures
  14. 98-4-8 MAR 98 Air Conditioning, R-12 to R-134A Retrofit Kit
  15. 98-5-2 MAR 98 Tire Company Telephone Numbers - Customer Assistance
  16. 97-25-5 DEC 97 Chirping/Squeaking From Blower Motor At Low Speeds
  17. 97-17-2 AUG 97 Rear View Mirror Reattachment
  18. 97811 APR 97 Whining/Howling Noise from Rear Axle
  19. 9768 MAR 97 Fuel Economy - Customer Expectations Vs. Vehicle Usage
  20. 962612 DEC 96 Torque Converter Cleaning and Replacement Guidelines
  21. 96246 NOV 96 Electrical Diode Identification and Replacement
  22. 96249 NOV 96 Service Tip - Torque Converter Leak Test Procedure
  23. 96221 OCT 96 Fog/Film on Windshield/Interior Glass
  24. 96214 OCT 96 Alternator Discharge - Harness Connector Damaged
  25. 961710 AUG 96 Use of R-12 Refrigerant Substitutes - Service Tip
  26. 96164 JUL 96 Ford's Position On Propylene Glycol Coolant
  27. 96156 JUL 96 A/C System Service TSB List
  28. 96129 JUN 96 Chatter During Turns After Extended Highway Driving
  29. 96107 MAY 96 California Reformulated Gasoline (CARFG) Service Tip
  30. 9611 JAN 96 New Torque Specs For Installing New Design Tie Rods
  31. 95243 DEC 95 Rocker Arm Squeak, Chirp or Knock Noise
  32. 95233 NOV 95 Air Conditioning - Water Drips On Floor
  33. 95203 OCT 95 Groaning Noise From Power Windows
  34. 95184 SEP 95 Air Conditioning - Ford Approved Flushing
  35. 95182 SEP 95 Recycled Engine Coolant - Service Tips
  36. 95185 SEP 95 Temperature Gauge - Fluctuation/Inaccurate
  37. 951610 AUG 95 New Rotunda Fluid Changer - Service Tip
  38. 95132 JUL 95 Temperature Gauge Reads Low/Erratic
  39. 95121 JUN 95 Windshield,Urethane Mounted, Material Usage Tip
  40. 9582 APR 95 Wiper Motor - Upgraded Service Kits
  41. 9562 MAR 95 Brakes - Roughness During Brake Application
  42. 9561 MAR 95 Paint - Iron Particle Removal
  43. 95512 MAR 95 Adding Refrigerant Oil Procedure
  44. 9552 MAR 95 Windshield Sealer Drips on Interior Trim
  45. 9522 JAN 95 Air Conditioning O-Ring Removal - Service Tip
  46. ATRATB277 JAN 95 Harsh 4-3 Kickdown - Valve Body Repair
  47. 94255 DEC 94 Anti-Theft Protection - Recap of TSB's - Service Tips
  48. 94252 DEC 94 Brake Rotor Machining Equipment and Warranty Information
  49. 94234 NOV 94 Paint Preparation Procedure And MSDS Information
  50. 94201 OCT 94 Front Seat Track Covers - Come Off When Moved Rearward
  51. 94172 AUG 94 Rear View Mirror - Detaches From Windshield
  52. 94-14-3 JUL 94 R-12 Refrigerant Substitutes
  53. 94114 JUN 94 A/C - Evaporator Core and Case Assembly Application
  54. 941112 JUN 94 Rear Axle Lubricant Leakage Through Cover Vent/Hose
  55. 941010 MAY 94 Revised Lower Intake Bolt/Stud Torque Procedure
  56. 9489 APR 94 Fuel Injector Cleaner - Parts and Service Tips
  57. 94212 JAN 94 A/C - Water Leaks From the Floor Ducts
  58. 9429 JAN 94 Air Conditioning - Poor Performance
  59. 9424 JAN 94 Instrument Panel - Cluster Finish Panel Loose
  60. 9415 JAN 94 Service Parts Return of Obsolete Fuel Pressure Regulator
  61. ATRATB254 JAN 94 Cooler Return Line - Filter Installation
  62. 93265 DEC 93 Air In Power Steering System
  63. 93261 DEC 93 Heated Backlite Inoperative
  64. 932612 DEC 93 Return of Obsolete Starter Solenoids and Starter Drives
  65. 93252 DEC 93 A/C Evaporator Tube Worn By Canister Purge Hose
  66. 93241 NOV 93 Bumper Cover Repair Materials
  67. 932410 NOV 93 Instrument Cluster Warning Lights
  68. 93248 NOV 93 Rough Idle/Hesitation/ Poor Heater Output
  69. 932318 NOV 93 AOD Transmission - Diagnostic Information
  70. 93236 NOV 93 EGO Sensors - Silicone Contamination
  71. 932314 NOV 93 Engine Gasket Surface Cleaning Procedures
  72. 93231 NOV 93 Moon Roof - Wind Noise When Fully Open
  73. 93226 OCT 93 Air Conditioning - Return of Obsolete Filter Kits
  74. 93211 OCT 93 Glass - Iridescence or Mottling In Tempered Glass
  75. 93206 SEP 93 Air Conditioning - Use of Correct Fluorescent Tracer DYE
  76. 9319B6 SEP 93 Body Collision Repair Manual Revised
  77. 931511 JUL 93 Labor Times Standards
  78. 93132 JUN 93 Tie Rod End (Inner) - Replacement Procedure
  79. 93126 JUN 93 Engine Stalls/Hesitates/Long Cranking Times
  80. 93129 JUN 93 Speedometer - Service Replacements With Pre-Set Mileage
  81. 9384 APR 93 Exterior Clearcoat May Crack, Erode or Peel Off
  82. 9365 MAR 93 A/C Coupling Cleaning Procedures/New O-Ring Available
  83. 9363 MAR 93 Rear Brake Pulsation
  84. 9351 MAR 93 Front Seat Feels Loose
  85. 93312 FEB 93 Moan or Slow Beating Noise From Axle While Driving 55MPH
  86. 9322 JAN 93 Power Door Lock Inoperative
  87. 93110 JAN 93 Cooling System - Proper Fluid Concentration
  88. 92252 DEC 92 Engine Repair Tips to Avoid Potential Engine Damage
  89. 92246 NOV 92 FX15 A/C Compressor - Oil Recovery & Measuring Procedure
  90. 92236 NOV 92 Noise, Whine - AOD Transmission.
  91. 92211 OCT 92 False Security Alarm - Bend Tank Lock Switch TAB
  92. 92205 SEP 92 A/C Clutch Slip At High Ambient Temperature
  93. 9218B3 SEP 92 Active Suspension Diagnostic Test A1, Code 15 and 25
  94. 92184 AUG 92 A/C FX-15 Compressor Oil Recovery & Measuring Procedures
  95. 92174 AUG 92 Moan From A/C Compressor At Idle to 1,500RPM
  96. 9211B1 JUN 92 Revised Procedure For Starter Motor Brushes Replacement
  97. 92128 JUN 92 A/C Condensation Enters Into Passenger Compartment
  98. 92124 JUN 92 Brakes-Rotor-Replacement Service Tips
  99. 92112 MAY 92 Front Door Glass May Separate From the Glass Bracket
  100. 9258 FEB 92 A/C FX-15 Compressor Clutch Shaft and Hub Assembly
  101. 9251 FEB 92 Safety Belts - Front/Rear Twisted
  102. 9243 FEB 92 Brakes - Roughness, Pulsation or Steering Wheel Shake
  103. 9247 FEB 92 Radio - Buzz/Whine and Ignition Noise
  104. 92M78 JAN 92 Daytime Running Lights Control Module
  105. 9232 JAN 92 High Efforts Depressing the Horn Pad to Sound the Horn
  106. 9233 JAN 92 Oil Pan Front Cover Gasket Leaks Oil
  107. 9223 JAN 92 Power Seat Operation Slow, Stalled and/or Inoperative
  108. ATRATB088 JAN 92 Ford Electronic Engine Control Trouble Codes
  109. ATRATB089 JAN 92 Ford Service Codes 1983-1990
  110. 91257 DEC 91 Hard Cold Starts, Hesitation, Stalls On Initial Start-Up
  111. 91247 NOV 91 Check For Ignition Pinpoint Tests - Service Tips
  112. ATRATB078 NOV 91 How To Use A Pressure Gauge - Automatic Trans.
  113. 91225 OCT 91 New Refrigerant O-Rings (Green Color)
  114. 91193 SEP 91 New Method of Fuel Injector Cleaning
  115. 91195 SEP 91 Power Window Regulator Counterbalance Spring
  116. 91181 SEP 91 Exterior Paint Repair Procedures
  117. 91188 SEP 91 Radio Sound Distortion From Speakers
  118. 91177 AUG 91 Hissing Noise From the Tape Player
  119. 911612 AUG 91 AOD Increased Shift Times
  120. 91155 JUL 91 "Refrigerator Type Smell" or Odor From A/C System
  121. 91151 JUL 91 Water Leaks On Passenger Side Front Floor
  122. ATRATB063 JUL 91 Direct Clutch Failure - Excessive Case Bore Wear
  123. 91136 JUN 91 Exhaust Moan or Vibration Occur At About 2100 RPM
  124. 91134 JUN 91 Fuel Gauge Intermittently Shows Increase In Fuel Level
  125. 9111B5 JUN 91 IDM and Spark Timing Diagnosis Manual Revision
  126. 9111B6 JUN 91 Revised Octane Adjust Shorting Bar Procedures
  127. 9111B11 JUN 91 Revised Supercharger Diagnostic Procedures
  128. 911114 MAY 91 Harsh or Rough Transmission Shifts
  129. 91111 MAY 91 Windnoise From Standard Antenna
  130. 91108 MAY 91 Battery In A Low State of Charge Causing A No Crank Condition
  131. 911010 MAY 91 Battery Test Procedure
  132. 911011 MAY 91 Loctite 510 Only From Loctite Distributors
  133. 91101 MAY 91 Service Part Information For Passive Restraint
  134. 9195 MAY 91 Driveability Problems Caused By EEC IV Processor
  135. 9192 MAY 91 Paint Blistering or Peeling Off Bumper Covers
  136. 9197 MAY 91 Service Tips On Usage of R-12
  137. 9184 APR 91 Unacceptable Door Latches
  138. 91813 APR 91 Use of Unleaded Gasolines to Avoid Driveability Problem
  139. 9171 APR 91 Damaged Passive Track Dust Seals
  140. 9175 APR 91 Processors Damage From Arc Welding
  141. 915B13 MAR 91 Refrigerant System Leak Manual Update
  142. 9151 MAR 91 Electric Rear Window Defroster Inoperative
  143. 9154 MAR 91 Wiper Arms Adjustment Procedure
  144. ATRATB045 MAR 91 No 4th, Late 4th, Falls Out Of 4th
  145. 9139 FEB 91 Transmission Noise, Delayed Shifts or No Engagements
  146. 9128 JAN 91 Analog Speedometer Inaccurate At High Speeds
  147. 9118 JAN 91 Torque Spec. For New Graphite Intake Manifold Gasket
  148. 9025B6 DEC 90 Horn/Speed Control Switch Assembly Manual Revision
  149. 9025B9 DEC 90 Keyless Entry System Connector Color Codes Revised
  150. 90261 DEC 90 Chattering From Motorized Passive Restraint System
  151. 90267 DEC 90 Poor Radio Reception
  152. 902510 DEC 90 High Effort When Depressing Horn
  153. 902512 DEC 90 Speed Control Diagnostic Tips
  154. 90246 NOV 90 Parking Brake Release Button May Separate From Handle
  155. 90239 NOV 90 Dim or Blank Display From Instrument Cluster
  156. 902310 NOV 90 Temp. Gauge Not Functioning Correctly, Supercharged Engines
  157. 90229 OCT 90 Authorized Audio Systems Service Centers
  158. 90226 OCT 90 Intermittent Brake Squeal
  159. ATRATB028 OCT 90 Engine Testing With A Vacuum Gauge - Auto Trans.
  160. 90195 SEP 90 Inoperative, Sticking or Slow Seat Track
  161. 90199 SEP 90 Use A Manual Torque Wrench to Tighten Wheel Nuts
  162. 9018B3 SEP 90 Pinpoint Test S, EGR Vacuum, Manual Revision
  163. 9018B6 SEP 90 Ride Control Test Fault Codes Revised
  164. 9018B7 SEP 90 Rotunda EVO System Tester Revised Information
  165. 9018B5 SEP 90 Speed Control, Manual Revision
  166. 9018B1 SEP 90 Speed Sensor Resistance Reading Manual Revision
  167. 9018B8 SEP 90 Split Fold-Down Rear Seat Manual Update
  168. 9018A1 SEP 90 Summary of Driveability TSB's
  169. 9018B2 SEP 90 Timing Procedure Manual Update
  170. 90183 AUG 90 Sticking Fuel Pump Relay
  171. 90163 AUG 90 No Crank Caused By the Anti-Theft Module
  172. 90153 JUL 90 Lower Body Stone Protection, Repair Procedure
  173. 90157 JUL 90 Speedometer Needle Fluctuation
  174. 90143 JUL 90 Procedure For Transit Coating Protection Removal
  175. 90132 JUN 90 Wheel Balance Weights
  176. 9012B2 JUN 90 Electronic Chime Diagnosis, Manual Revision
  177. 901210 JUN 90 A "Clicking" or "Buzzing" Noise From the Speed Control
  178. 90116 MAY 90 Disconnect the Battery Ground Cable If Arc Welding
  179. 906B32 MAR 90 Intercooler - Manual Revision
  180. 906B2 MAR 90 Suspension Specification, Manual Revision
  181. 9068 MAR 90 Sound From Rear Speakers May Be Distorted
  182. MEMO0390 MAR 90 Initial VECI Decal Index For Model Year 1990
  183. 90410 FEB 90 Recycled Engine Coolant Not Authorized
  184. ATRATB9002006 FEB 90 Automatic Transmission Fluid
  185. 9031 JAN 90 Loose or Broken Hood Lift Retainers
  186. 9038 JAN 90 VMM Oil Change Indicator Reset Procedure
  187. 9021 JAN 90 Front Seat Shoulder/Lap Safety Belt Changes
  188. 9018 JAN 90 Ford RTV Sealer Shelf Life
  189. 8925B1 DEC 89 A/C & Heater Odor Treatment
  190. 8925A1 DEC 89 New Service Procedure For Loose/Broken Hood Lift
  191. 89251 DEC 89 Ignition Key Hard to Remove
  192. 89243 DEC 89 Predelivery Service Record
  193. RSB89170 NOV 89 Defective Fuel Pump and Sender Assys
  194. MEMO891121 NOV 89 Return of Door Window Bracket Assembly
  195. 89237 NOV 89 AOD Transmission Gasket Changes
  196. 89222 NOV 89 A/C Compressor Shaft Seal Leaks
  197. ATRATB8930 OCT 89 Automatic Transmission Math Part 2
  198. 89192 SEP 89 Ignition Key Warning Switch-Replacement Procedure
  199. 89195 SEP 89 Wire Harness Terminal and Connector Service Kit
  200. ATRATB8927 SEP 89 20 Steps To successful Auto Transmission Repair
  201. 8918A3 SEP 89 Manual Revision On Outside Mirror Glass Replacement Procedures
  202. 89173 AUG 89 Aluminum Wheel - Air Leaks
  203. 89175 AUG 89 EEC Connector Color Code Changes
  204. 891712 AUG 89 Lamps-Running Lights Flicker "On" and "Off", Canadian Units
  205. 89174 AUG 89 Removal of Bright Green Colored Sticker
  206. 89161 AUG 89 Outside Mirror Replacement Manual Correction
  207. ATRATB8923 AUG 89 Automatic Transmission Math Formulas
  208. ATRATB8922 JUL 89 Governor Pressure Leaks
  209. 8912689614 JUN 89 AOD 3-4, Shift Accumulators Not Used In 1990 Built Transmission
  210. TECGLOS JUN 89 Technician's Glossary (Emission Related)
  211. 89104 MAY 89 C-11 Power Steering Pump New Design Fitting At Pump Outlet
  212. TECGLOS MAY 89 Technician's Glossary (Electrical/Electronic and Fuel Induction
  213. ATRASIL8910 MAR 89 3-4 Accumulator Change
  214. 88133 JUN 88 Protection From Static Electricity
  215. ATRATB8754 SEP 87 All Automatics - Front Bushing Wear
  216. ATRATB8748 AUG 87 Metal Sealing Rings - Automatic Transmissions
ALLDATA has obtained this information from the original
equipment manufacturers and others and ALLDATA believes it to be reliable.
However, ALLDATA makes no warranty regarding the information, express or
implied, and accepts no responsibility for the accurancy or completeness
of the information provided.
In no event shall ALLDATA be liable for any damages arising from the use or
misuse of this information, including, but not limited to, any direct, indirect,
incidental, special or consequential damages arising out of the use or inability
to use this information.
Copyright © 1996-2000 ALLDATA
LLC
. All Rights Reserved.
1 - 1 of 2 Posts
Status
