Status
Not open for further replies.
1 - 1 of 2 Posts
Bulletins for 1991 Ford Thunderbird V6-232 3.8L SC
Safety Recalls
TSB Number Issue Date TSB Title
  1. 95S28 NOV 95 Safety Recall 95S28 - Ignition Switch Replacement
  2. 91S29 JUL 91 Recall 91S29 Parking Pawl Actuating Rod, Replacement
  3. 91S34 MAY 91 Recall 91S34 Loose Windshield Wiper Motor Attaching Nuts
General Recalls
  1. 93B31 DEC 93 Throttle Body Lever Grommet - Recall 93B31
  2. 92B11 OCT 92 Recall 92B11 - Front Disc Roughness, Brakes Shudder
Service Bulletins
  1. 99-8-16 MAY 99 Motor Oil-SAE 5W-30 Viscosity Grade Recommendation
  2. 99-6-3 APR 99 Wire Splicing And Wire Harness Terminal Repair Kit
  3. 98-26-2 JAN 99 Tips To Resolve Volatility Related Driveability Concerns
  4. 98-23-10 NOV 98 Mass Air Flow Sensor Contamination-Service Tip
  5. 98-18-14 SEP 98 A/C-Water Drips On Floor-High Blower/MAX-NORMAL A/C Mode
  6. 98-17-1 SEP 98 Seat-Leather Cleaning Procedure-Service Tip
  7. 98-12-5 JUN 98 A/C-Filtering Refrigerant After Compressor Replacement
  8. 98-12-8 JUN 98 A/C-Identifying Non-Ford Approved Refrigerants
  9. 98-8-8 APR 98 Automatic Transmission Fluid Usage Charts
  10. 98-7-4 APR 98 Oil Leaks-New Silicone Gasket And Sealant
  11. 98-7-3 APR 98 Whining/Buzzing Noise Through Radio Speaker
  12. 98-5A-13 MAR 98 Brakes-New Application-Silicone Compound/Grease
  13. 98-5A-4 MAR 98 Preventing Brake Vibration, Lug Nut Torque Procedures
  14. 98-4-8 MAR 98 Air Conditioning, R-12 to R-134A Retrofit Kit
  15. 98-5-2 MAR 98 Tire Company Telephone Numbers - Customer Assistance
  16. 97-25-5 DEC 97 Chirping/Squeaking From Blower Motor At Low Speeds
  17. 97-17-2 AUG 97 Rear View Mirror Reattachment
  18. 97811 APR 97 Whining/Howling Noise from Rear Axle
  19. 9768 MAR 97 Fuel Economy - Customer Expectations Vs. Vehicle Usage
  20. 962612 DEC 96 Torque Converter Cleaning and Replacement Guidelines
  21. 96246 NOV 96 Electrical Diode Identification and Replacement
  22. 96249 NOV 96 Service Tip - Torque Converter Leak Test Procedure
  23. 96221 OCT 96 Fog/Film on Windshield/Interior Glass
  24. 96214 OCT 96 Alternator Discharge - Harness Connector Damaged
  25. 961710 AUG 96 Use of R-12 Refrigerant Substitutes - Service Tip
  26. 96164 JUL 96 Ford's Position On Propylene Glycol Coolant
  27. 96156 JUL 96 A/C System Service TSB List
  28. 96149 JUL 96 Squeal or Hoot Noise From FEAD
  29. 96129 JUN 96 Chatter During Turns After Extended Highway Driving
  30. 96107 MAY 96 California Reformulated Gasoline (CARFG) Service Tip
  31. 9611 JAN 96 New Torque Specs For Installing New Design Tie Rods
  32. 95243 DEC 95 Rocker Arm Squeak, Chirp or Knock Noise
  33. 95233 NOV 95 Air Conditioning - Water Drips On Floor
  34. 95203 OCT 95 Groaning Noise From Power Windows
  35. 95184 SEP 95 Air Conditioning - Ford Approved Flushing
  36. 95182 SEP 95 Recycled Engine Coolant - Service Tips
  37. 95185 SEP 95 Temperature Gauge - Fluctuation/Inaccurate
  38. 951610 AUG 95 New Rotunda Fluid Changer - Service Tip
  39. 95132 JUL 95 Temperature Gauge Reads Low/Erratic
  40. 95121 JUN 95 Windshield,Urethane Mounted, Material Usage Tip
  41. 9582 APR 95 Wiper Motor - Upgraded Service Kits
  42. 9562 MAR 95 Brakes - Roughness During Brake Application
  43. 9561 MAR 95 Paint - Iron Particle Removal
  44. 95512 MAR 95 Adding Refrigerant Oil Procedure
  45. 9552 MAR 95 Windshield Sealer Drips on Interior Trim
  46. 9522 JAN 95 Air Conditioning O-Ring Removal - Service Tip
  47. ATRATB277 JAN 95 Harsh 4-3 Kickdown - Valve Body Repair
  48. 94255 DEC 94 Anti-Theft Protection - Recap of TSB's - Service Tips
  49. 94252 DEC 94 Brake Rotor Machining Equipment and Warranty Information
  50. 94234 NOV 94 Paint Preparation Procedure And MSDS Information
  51. 94201 OCT 94 Front Seat Track Covers - Come Off When Moved Rearward
  52. 94182 SEP 94 Front Seat - Loose or Clunk When Braking or Accelerating
  53. 94172 AUG 94 Rear View Mirror - Detaches From Windshield
  54. 94169 AUG 94 Heated Exhaust Gas Oxygen Sensor Application Chart
  55. 94142 JUL 94 Emission Control - Air Bypass Valve Replacement
  56. 94-14-3 JUL 94 R-12 Refrigerant Substitutes
  57. 94114 JUN 94 A/C - Evaporator Core and Case Assembly Application
  58. 941112 JUN 94 Rear Axle Lubricant Leakage Through Cover Vent/Hose
  59. 941011 MAY 94 Clunk From Rear End During Turning Maneuvers
  60. 9489 APR 94 Fuel Injector Cleaner - Parts and Service Tips
  61. 94212 JAN 94 A/C - Water Leaks From the Floor Ducts
  62. 9429 JAN 94 Air Conditioning - Poor Performance
  63. 9424 JAN 94 Instrument Panel - Cluster Finish Panel Loose
  64. 9415 JAN 94 Service Parts Return of Obsolete Fuel Pressure Regulator
  65. ATRATB254 JAN 94 Cooler Return Line - Filter Installation
  66. 93265 DEC 93 Air In Power Steering System
  67. 93261 DEC 93 Heated Backlite Inoperative
  68. 932612 DEC 93 Return of Obsolete Starter Solenoids and Starter Drives
  69. 93252 DEC 93 A/C Evaporator Tube Worn By Canister Purge Hose
  70. 93241 NOV 93 Bumper Cover Repair Materials
  71. 932410 NOV 93 Instrument Cluster Warning Lights
  72. 93248 NOV 93 Rough Idle/Hesitation/ Poor Heater Output
  73. 932318 NOV 93 AOD Transmission - Diagnostic Information
  74. 93236 NOV 93 EGO Sensors - Silicone Contamination
  75. 932314 NOV 93 Engine Gasket Surface Cleaning Procedures
  76. 93231 NOV 93 Moon Roof - Wind Noise When Fully Open
  77. 93226 OCT 93 Air Conditioning - Return of Obsolete Filter Kits
  78. 93211 OCT 93 Glass - Iridescence or Mottling In Tempered Glass
  79. 93206 SEP 93 Air Conditioning - Use of Correct Fluorescent Tracer DYE
  80. 9319B6 SEP 93 Body Collision Repair Manual Revised
  81. 93197 SEP 93 AOD Transmission - Shudder In Reverse
  82. 93157 JUL 93 Fuel Injectors - Identification Information
  83. 931511 JUL 93 Labor Times Standards
  84. 93132 JUN 93 Tie Rod End (Inner) - Replacement Procedure
  85. 93126 JUN 93 Engine Stalls/Hesitates/Long Cranking Times
  86. 93129 JUN 93 Speedometer - Service Replacements With Pre-Set Mileage
  87. 9384 APR 93 Exterior Clearcoat May Crack, Erode or Peel Off
  88. 9365 MAR 93 A/C Coupling Cleaning Procedures/New O-Ring Available
  89. 9363 MAR 93 Rear Brake Pulsation
  90. 9351 MAR 93 Front Seat Feels Loose
  91. 93312 FEB 93 Moan or Slow Beating Noise From Axle While Driving 55MPH
  92. 9322 JAN 93 Power Door Lock Inoperative
  93. 93110 JAN 93 Cooling System - Proper Fluid Concentration
  94. 92264 DEC 92 Poor or Inadequate A/C Cooling
  95. 92255 DEC 92 A/C Application Chart For the FX15 Clutch, Coil & Pulley
  96. 92252 DEC 92 Engine Repair Tips to Avoid Potential Engine Damage
  97. 92246 NOV 92 FX15 A/C Compressor - Oil Recovery & Measuring Procedure
  98. 92243 NOV 92 Service Engine Soon Lamp On With No Self Test Code
  99. 92236 NOV 92 Noise, Whine - AOD Transmission.
  100. 92211 OCT 92 False Security Alarm - Bend Tank Lock Switch TAB
  101. 92213 OCT 92 Fuel Gage Not Reading Correctly Tank Reservoir Distorted
  102. 92205 SEP 92 A/C Clutch Slip At High Ambient Temperature
  103. 9218B3 SEP 92 Active Suspension Diagnostic Test A1, Code 15 and 25
  104. 92184 AUG 92 A/C FX-15 Compressor Oil Recovery & Measuring Procedures
  105. 92174 AUG 92 Moan From A/C Compressor At Idle to 1,500RPM
  106. 92128 JUN 92 A/C Condensation Enters Into Passenger Compartment
  107. 92124 JUN 92 Brakes-Rotor-Replacement Service Tips
  108. 9294 APR 92 Poor Air Conditioning Cooling Performance
  109. 9292 APR 92 Stumbles or Stalls When (TFI) Module Gets Wet
  110. 9258 FEB 92 A/C FX-15 Compressor Clutch Shaft and Hub Assembly
  111. 9251 FEB 92 Safety Belts - Front/Rear Twisted
  112. 9243 FEB 92 Brakes - Roughness, Pulsation or Steering Wheel Shake
  113. 9244 FEB 92 Overview of EEC-IV Self-Test Codes and MIL Service Tips
  114. 9247 FEB 92 Radio - Buzz/Whine and Ignition Noise
  115. 92M78 JAN 92 Daytime Running Lights Control Module
  116. 9232 JAN 92 High Efforts Depressing the Horn Pad to Sound the Horn
  117. 9233 JAN 92 Oil Pan Front Cover Gasket Leaks Oil
  118. 9125B5 DEC 91 Tripminder Information - Manual Revision
  119. 912510 DEC 91 Popping Noise or Distortion In Right Speakers
  120. 91247 NOV 91 Check For Ignition Pinpoint Tests - Service Tips
  121. ATRATB078 NOV 91 How To Use A Pressure Gauge - Automatic Trans.
  122. 91225 OCT 91 New Refrigerant O-Rings (Green Color)
  123. 91197 SEP 91 False Low Fuel Warning Light, Intermittently
  124. 91193 SEP 91 New Method of Fuel Injector Cleaning
  125. 91195 SEP 91 Power Window Regulator Counterbalance Spring
  126. 91181 SEP 91 Exterior Paint Repair Procedures
  127. 91188 SEP 91 Radio Sound Distortion From Speakers
  128. MEMO080191 AUG 91 Elimination of the Computer Assisted Recall
  129. 91155 JUL 91 "Refrigerator Type Smell" or Odor From A/C System
  130. 91151 JUL 91 Water Leaks On Passenger Side Front Floor
  131. 91144 JUL 91 Idle Rough, Stalls, Misses, Codes 173 and 177
  132. ATRATB063 JUL 91 Direct Clutch Failure - Excessive Case Bore Wear
  133. 91136 JUN 91 Exhaust Moan or Vibration Occur At About 2100 RPM
  134. 91135 JUN 91 MIL May Mistakenly Display Continuous Codes 173/177
  135. 9111B5 JUN 91 IDM and Spark Timing Diagnosis Manual Revision
  136. 9111B10 JUN 91 Page Number Reference For R&I Temp. Control - Revised
  137. 9111B3 JUN 91 Revised Ign Diagnostics to Support TFI Diagnostic Cable
  138. 9111B6 JUN 91 Revised Octane Adjust Shorting Bar Procedures
  139. 9111B11 JUN 91 Revised Supercharger Diagnostic Procedures
  140. 9111B9 JUN 91 The Electronic Automatic Temp. Control Revised
  141. 91111 MAY 91 Windnoise From Standard Antenna
  142. 91108 MAY 91 Battery In A Low State of Charge Causing A No Crank Condition
  143. 911010 MAY 91 Battery Test Procedure
  144. 911011 MAY 91 Loctite 510 Only From Loctite Distributors
  145. 91101 MAY 91 Service Part Information For Passive Restraint
  146. 9192 MAY 91 Paint Blistering or Peeling Off Bumper Covers
  147. 9197 MAY 91 Service Tips On Usage of R-12
  148. 9184 APR 91 Unacceptable Door Latches
  149. 91813 APR 91 Use of Unleaded Gasolines to Avoid Driveability Problem
  150. 9175 APR 91 Processors Damage From Arc Welding
  151. 915B13 MAR 91 Refrigerant System Leak Manual Update
  152. 9162 MAR 91 Revised 1991 Fleet Color Paint Code Numbers
  153. 9154 MAR 91 Wiper Arms Adjustment Procedure
  154. ATRATB045 MAR 91 No 4th, Late 4th, Falls Out Of 4th
  155. 9118 JAN 91 Torque Spec. For New Graphite Intake Manifold Gasket
  156. 9025B9 DEC 90 Keyless Entry System Connector Color Codes Revised
  157. 9025B1 DEC 90 Pinpoint Test H, Manual Correction
  158. 90261 DEC 90 Chattering From Motorized Passive Restraint System
  159. 90269 DEC 90 New Pre-Delivery Forms
  160. 90267 DEC 90 Poor Radio Reception
  161. 902512 DEC 90 Speed Control Diagnostic Tips
  162. 90239 NOV 90 Dim or Blank Display From Instrument Cluster
  163. 902310 NOV 90 Temp. Gauge Not Functioning Correctly, Supercharged Engines
  164. 90229 OCT 90 Authorized Audio Systems Service Centers
  165. 902212 OCT 90 Engine Oil Fill Capacities
  166. 90226 OCT 90 Intermittent Brake Squeal
  167. ATRATB028 OCT 90 Engine Testing With A Vacuum Gauge - Auto Trans.
  168. 90199 SEP 90 Use A Manual Torque Wrench to Tighten Wheel Nuts
  169. ATRATB9002006 FEB 90 Automatic Transmission Fluid
  170. ATRATB8930 OCT 89 Automatic Transmission Math Part 2
  171. ATRATB8927 SEP 89 20 Steps To successful Auto Transmission Repair
  172. ATRATB8923 AUG 89 Automatic Transmission Math Formulas
  173. ATRASIL8910 MAR 89 3-4 Accumulator Change
  174. ATRATB8754 SEP 87 All Automatics - Front Bushing Wear
  175. ATRATB8748 AUG 87 Metal Sealing Rings - Automatic Transmissions
ALLDATA has obtained this information from the original
equipment manufacturers and others and ALLDATA believes it to be reliable.
However, ALLDATA makes no warranty regarding the information, express or
implied, and accepts no responsibility for the accurancy or completeness
of the information provided.
In no event shall ALLDATA be liable for any damages arising from the use or
misuse of this information, including, but not limited to, any direct, indirect,
incidental, special or consequential damages arising out of the use or inability
to use this information.
Copyright © 1996-2000 ALLDATA
LLC
. All Rights Reserved.
1 - 1 of 2 Posts
Status
