Status
Not open for further replies.
1 - 1 of 2 Posts
Bulletins for 1992 Ford Thunderbird V6-232 3.8L SC
Safety Recalls
TSB Number Issue Date TSB Title
  1. 95S28 NOV 95 Safety Recall 95S28 - Ignition Switch Replacement
Emissions Recalls
  1. 92E24 MAR 92 Recall 92E24
General Recalls
  1. 93B31 DEC 93 Throttle Body Lever Grommet - Recall 93B31
Service Bulletins
  1. 99-8-16 MAY 99 Motor Oil-SAE 5W-30 Viscosity Grade Recommendation
  2. 99-6-3 APR 99 Wire Splicing And Wire Harness Terminal Repair Kit
  3. 98-26-2 JAN 99 Tips To Resolve Volatility Related Driveability Concerns
  4. 98-23-10 NOV 98 Mass Air Flow Sensor Contamination-Service Tip
  5. 98-18-14 SEP 98 A/C-Water Drips On Floor-High Blower/MAX-NORMAL A/C Mode
  6. 98-17-1 SEP 98 Seat-Leather Cleaning Procedure-Service Tip
  7. 98-12-5 JUN 98 A/C-Filtering Refrigerant After Compressor Replacement
  8. 98-12-8 JUN 98 A/C-Identifying Non-Ford Approved Refrigerants
  9. 98-9-9 MAY 98 Fuel Injectors, Non-Warranty Reimbursement Testing
  10. 98-8-8 APR 98 Automatic Transmission Fluid Usage Charts
  11. 98-7-4 APR 98 Oil Leaks-New Silicone Gasket And Sealant
  12. 98-7-3 APR 98 Whining/Buzzing Noise Through Radio Speaker
  13. 98-5A-13 MAR 98 Brakes-New Application-Silicone Compound/Grease
  14. 98-5A-4 MAR 98 Preventing Brake Vibration, Lug Nut Torque Procedures
  15. 98-4-8 MAR 98 Air Conditioning, R-12 to R-134A Retrofit Kit
  16. 98-5-2 MAR 98 Tire Company Telephone Numbers - Customer Assistance
  17. 98-2-7 FEB 98 Air Conditioning Musty And Mildew Type Odors
  18. 97-25-5 DEC 97 Chirping/Squeaking From Blower Motor At Low Speeds
  19. 97-17-2 AUG 97 Rear View Mirror Reattachment
  20. 97811 APR 97 Whining/Howling Noise from Rear Axle
  21. 9768 MAR 97 Fuel Economy - Customer Expectations Vs. Vehicle Usage
  22. 962612 DEC 96 Torque Converter Cleaning and Replacement Guidelines
  23. 96246 NOV 96 Electrical Diode Identification and Replacement
  24. 96249 NOV 96 Service Tip - Torque Converter Leak Test Procedure
  25. 96221 OCT 96 Fog/Film on Windshield/Interior Glass
  26. 96225 OCT 96 Replacement of the Mass Air Flow Sensor as an Assembly
  27. 96214 OCT 96 Alternator Discharge - Harness Connector Damaged
  28. 96207 SEP 96 Air Conditioning O-Ring Availability and Applications
  29. 96208 SEP 96 Air Conditioning Thick O-Ring Applications
  30. 961710 AUG 96 Use of R-12 Refrigerant Substitutes - Service Tip
  31. 96164 JUL 96 Ford's Position On Propylene Glycol Coolant
  32. 96156 JUL 96 A/C System Service TSB List
  33. 96149 JUL 96 Squeal or Hoot Noise From FEAD
  34. 96129 JUN 96 Chatter During Turns After Extended Highway Driving
  35. 96107 MAY 96 California Reformulated Gasoline (CARFG) Service Tip
  36. 9611 JAN 96 New Torque Specs For Installing New Design Tie Rods
  37. ATRATB327 JAN 96 Output Shaft Pin Location/Updated Shaft
  38. ATRATB359 JAN 96 Revised Forward Sprag Race
  39. ATRATB358 JAN 96 Valve Body Cross Leaks
  40. 95243 DEC 95 Rocker Arm Squeak, Chirp or Knock Noise
  41. 95233 NOV 95 Air Conditioning - Water Drips On Floor
  42. 95184 SEP 95 Air Conditioning - Ford Approved Flushing
  43. 95182 SEP 95 Recycled Engine Coolant - Service Tips
  44. 95185 SEP 95 Temperature Gauge - Fluctuation/Inaccurate
  45. 951610 AUG 95 New Rotunda Fluid Changer - Service Tip
  46. 95131 JUL 95 A/C Evaporator Core-On Vehicle-Leak Test
  47. 95132 JUL 95 Temperature Gauge Reads Low/Erratic
  48. 95121 JUN 95 Windshield,Urethane Mounted, Material Usage Tip
  49. 9582 APR 95 Wiper Motor - Upgraded Service Kits
  50. 9562 MAR 95 Brakes - Roughness During Brake Application
  51. 9561 MAR 95 Paint - Iron Particle Removal
  52. 95512 MAR 95 Adding Refrigerant Oil Procedure
  53. 9552 MAR 95 Windshield Sealer Drips on Interior Trim
  54. 9522 JAN 95 Air Conditioning O-Ring Removal - Service Tip
  55. ATRATB314 JAN 95 Delayed Engagement, Shift Errors, Possible MLPS Codes
  56. ATRATB277 JAN 95 Harsh 4-3 Kickdown - Valve Body Repair
  57. ATRATB305 JAN 95 Shifts To Neutral At Heavy Throttle
  58. 94263 DEC 94 No Crank - Possible Corrosion At Starter Solenoid
  59. 94252 DEC 94 Brake Rotor Machining Equipment and Warranty Information
  60. 94234 NOV 94 Paint Preparation Procedure And MSDS Information
  61. 94201 OCT 94 Front Seat Track Covers - Come Off When Moved Rearward
  62. 94182 SEP 94 Front Seat - Loose or Clunk When Braking or Accelerating
  63. 94172 AUG 94 Rear View Mirror - Detaches From Windshield
  64. 94169 AUG 94 Heated Exhaust Gas Oxygen Sensor Application Chart
  65. 94142 JUL 94 Emission Control - Air Bypass Valve Replacement
  66. 94-14-3 JUL 94 R-12 Refrigerant Substitutes
  67. 94114 JUN 94 A/C - Evaporator Core and Case Assembly Application
  68. 94115 JUN 94 Heater/ A/C - Cold Engine Lockout Operation
  69. 941112 JUN 94 Rear Axle Lubricant Leakage Through Cover Vent/Hose
  70. 941011 MAY 94 Clunk From Rear End During Turning Maneuvers
  71. 94212 JAN 94 A/C - Water Leaks From the Floor Ducts
  72. 9429 JAN 94 Air Conditioning - Poor Performance
  73. 9424 JAN 94 Instrument Panel - Cluster Finish Panel Loose
  74. 9415 JAN 94 Service Parts Return of Obsolete Fuel Pressure Regulator
  75. ATRATB254 JAN 94 Cooler Return Line - Filter Installation
  76. 93265 DEC 93 Air In Power Steering System
  77. 93261 DEC 93 Heated Backlite Inoperative
  78. 932612 DEC 93 Return of Obsolete Starter Solenoids and Starter Drives
  79. 93252 DEC 93 A/C Evaporator Tube Worn By Canister Purge Hose
  80. 93253 DEC 93 A/C and Accessory Drive Belt Breakage/Squeal
  81. 93241 NOV 93 Bumper Cover Repair Materials
  82. 932410 NOV 93 Instrument Cluster Warning Lights
  83. 932412 NOV 93 Remote Keyless Entry System
  84. 93248 NOV 93 Rough Idle/Hesitation/ Poor Heater Output
  85. 932318 NOV 93 AOD Transmission - Diagnostic Information
  86. 93236 NOV 93 EGO Sensors - Silicone Contamination
  87. 932314 NOV 93 Engine Gasket Surface Cleaning Procedures
  88. 93231 NOV 93 Moon Roof - Wind Noise When Fully Open
  89. 93226 OCT 93 Air Conditioning - Return of Obsolete Filter Kits
  90. 93211 OCT 93 Glass - Iridescence or Mottling In Tempered Glass
  91. ATRATB191 OCT 93 Failsafe Modes - Computer Shifted Transmissions
  92. 93206 SEP 93 Air Conditioning - Use of Correct Fluorescent Tracer DYE
  93. 9319B6 SEP 93 Body Collision Repair Manual Revised
  94. 9319B5 SEP 93 Instrument Cluster Pinpoint Tests Revised
  95. 93197 SEP 93 AOD Transmission - Shudder In Reverse
  96. 93157 JUL 93 Fuel Injectors - Identification Information
  97. 931511 JUL 93 Labor Times Standards
  98. 93132 JUN 93 Tie Rod End (Inner) - Replacement Procedure
  99. 93126 JUN 93 Engine Stalls/Hesitates/Long Cranking Times
  100. 93129 JUN 93 Speedometer - Service Replacements With Pre-Set Mileage
  101. 9391 APR 93 Ashtray Door Separated
  102. 9384 APR 93 Exterior Clearcoat May Crack, Erode or Peel Off
  103. 9363 MAR 93 Rear Brake Pulsation
  104. 9351 MAR 93 Front Seat Feels Loose
  105. 93312 FEB 93 Moan or Slow Beating Noise From Axle While Driving 55MPH
  106. 9322 JAN 93 Power Door Lock Inoperative
  107. 93110 JAN 93 Cooling System - Proper Fluid Concentration
  108. 92264 DEC 92 Poor or Inadequate A/C Cooling
  109. 92255 DEC 92 A/C Application Chart For the FX15 Clutch, Coil & Pulley
  110. 92252 DEC 92 Engine Repair Tips to Avoid Potential Engine Damage
  111. 92246 NOV 92 FX15 A/C Compressor - Oil Recovery & Measuring Procedure
  112. 92243 NOV 92 Service Engine Soon Lamp On With No Self Test Code
  113. 92236 NOV 92 Noise, Whine - AOD Transmission.
  114. 92213 OCT 92 Fuel Gage Not Reading Correctly Tank Reservoir Distorted
  115. 92205 SEP 92 A/C Clutch Slip At High Ambient Temperature
  116. 92192 SEP 92 Brake Pedal Slow or Does Not Completely Return (ABS)
  117. 92191 SEP 92 Door Glass Window Bind or Out of Channel
  118. 9218B3 SEP 92 Active Suspension Diagnostic Test A1, Code 15 and 25
  119. ATRATB132 SEP 92 Intermittent Electrical Problems
  120. 92184 AUG 92 A/C FX-15 Compressor Oil Recovery & Measuring Procedures
  121. 92174 AUG 92 Moan From A/C Compressor At Idle to 1,500RPM
  122. 92132 JUN 92 High Pitch Squeal From ST5EERING Gear Housing Cover
  123. 92128 JUN 92 A/C Condensation Enters Into Passenger Compartment
  124. 92124 JUN 92 Brakes-Rotor-Replacement Service Tips
  125. 92117 MAY 92 Terminology List - SAEJ1930
  126. 9294 APR 92 Poor Air Conditioning Cooling Performance
  127. 9265 MAR 92 Anti-Chip Primer Repair Procedure
  128. 9264 MAR 92 Rough Texture and/or Orange/Rust Dots
  129. 9258 FEB 92 A/C FX-15 Compressor Clutch Shaft and Hub Assembly
  130. 9252 FEB 92 New Identification Labels For Paint Code
  131. 9251 FEB 92 Safety Belts - Front/Rear Twisted
  132. 9243 FEB 92 Brakes - Roughness, Pulsation or Steering Wheel Shake
  133. 9244 FEB 92 Overview of EEC-IV Self-Test Codes and MIL Service Tips
  134. 9125B1 DEC 91 Ignition System Diagnostics Revised
  135. 912510 DEC 91 Popping Noise or Distortion In Right Speakers
  136. ATRATB078 NOV 91 How To Use A Pressure Gauge - Automatic Trans.
  137. 91225 OCT 91 New Refrigerant O-Rings (Green Color)
  138. 91181 SEP 91 Exterior Paint Repair Procedures
  139. ATRATB063 JUL 91 Direct Clutch Failure - Excessive Case Bore Wear
  140. ATRATB045 MAR 91 No 4th, Late 4th, Falls Out Of 4th
  141. 90269 DEC 90 New Pre-Delivery Forms
  142. ATRATB028 OCT 90 Engine Testing With A Vacuum Gauge - Auto Trans.
  143. ATRATB9002006 FEB 90 Automatic Transmission Fluid
  144. ATRATB8930 OCT 89 Automatic Transmission Math Part 2
  145. ATRATB8927 SEP 89 20 Steps To successful Auto Transmission Repair
  146. ATRATB8923 AUG 89 Automatic Transmission Math Formulas
  147. ATRASIL8910 MAR 89 3-4 Accumulator Change
  148. ATRATB8754 SEP 87 All Automatics - Front Bushing Wear
  149. ATRATB8748 AUG 87 Metal Sealing Rings - Automatic Transmissions
ALLDATA has obtained this information from the original
equipment manufacturers and others and ALLDATA believes it to be reliable.
However, ALLDATA makes no warranty regarding the information, express or
implied, and accepts no responsibility for the accurancy or completeness
of the information provided.
In no event shall ALLDATA be liable for any damages arising from the use or
misuse of this information, including, but not limited to, any direct, indirect,
incidental, special or consequential damages arising out of the use or inability
to use this information.
Copyright © 1996-2000 ALLDATA
LLC
. All Rights Reserved.
1 - 1 of 2 Posts
Status
