Status
Not open for further replies.
1 - 1 of 2 Posts
Bulletins for 1993 Ford Thunderbird V6-232 3.8L
Safety Recalls
TSB Number Issue Date TSB Title
  1. 95S28 NOV 95 Safety Recall 95S28 - Ignition Switch Replacement
General Recalls
  1. 93B31 DEC 93 Throttle Body Lever Grommet - Recall 93B31
Service Bulletins
  1. 99-8-16 MAY 99 Motor Oil-SAE 5W-30 Viscosity Grade Recommendation
  2. 99-6-3 APR 99 Wire Splicing And Wire Harness Terminal Repair Kit
  3. 98-26-2 JAN 99 Tips To Resolve Volatility Related Driveability Concerns
  4. 98-23-10 NOV 98 Mass Air Flow Sensor Contamination-Service Tip
  5. 98-20-10 OCT 98 Buzz/Rattle Noise-Loose Catalyst Or Muffler Heat Shield
  6. 98-18-14 SEP 98 A/C-Water Drips On Floor-High Blower/MAX-NORMAL A/C Mode
  7. 98-17-1 SEP 98 Seat-Leather Cleaning Procedure-Service Tip
  8. 98-12-5 JUN 98 A/C-Filtering Refrigerant After Compressor Replacement
  9. 98-12-8 JUN 98 A/C-Identifying Non-Ford Approved Refrigerants
  10. 98-9-9 MAY 98 Fuel Injectors, Non-Warranty Reimbursement Testing
  11. 98-8-8 APR 98 Automatic Transmission Fluid Usage Charts
  12. 98-7-4 APR 98 Oil Leaks-New Silicone Gasket And Sealant
  13. 98-7-3 APR 98 Whining/Buzzing Noise Through Radio Speaker
  14. 98-5A-6 MAR 98 Anti-Lock Brakes Cycling On Rough Roads
  15. 98-5A-5 MAR 98 Available Hub-Mount Brake Rotor Machining Equipment
  16. 98-5A-11 MAR 98 Brakes-Elimination Of Sanding Rotors And Drums
  17. 98-5A-13 MAR 98 Brakes-New Application-Silicone Compound/Grease
  18. 98-5A-4 MAR 98 Preventing Brake Vibration, Lug Nut Torque Procedures
  19. 98-5A-18 MAR 98 Roughness During Brake Application, 65 to 0 MPH
  20. 98-4-8 MAR 98 Air Conditioning, R-12 to R-134A Retrofit Kit
  21. 98-5-2 MAR 98 Tire Company Telephone Numbers - Customer Assistance
  22. 98-2-7 FEB 98 Air Conditioning Musty And Mildew Type Odors
  23. 97-25-5 DEC 97 Chirping/Squeaking From Blower Motor At Low Speeds
  24. 97-24-13 NOV 97 Remote Keyless Entry (RKE) Diagnostic Service Tips
  25. 97-19-4 SEP 97 Brake and Rotor Service Tips
  26. 97-19-11 SEP 97 On-Vehicle Heater Core Pressure Test For Warranty Claim
  27. 97-18-4 SEP 97 Radio Am Band Static While Driving
  28. 97-17-2 AUG 97 Rear View Mirror Reattachment
  29. 97-12-1 JUN 97 Windnoise Emanating from Moonroof
  30. 97811 APR 97 Whining/Howling Noise from Rear Axle
  31. 9768 MAR 97 Fuel Economy - Customer Expectations Vs. Vehicle Usage
  32. 962612 DEC 96 Torque Converter Cleaning and Replacement Guidelines
  33. 96246 NOV 96 Electrical Diode Identification and Replacement
  34. 96249 NOV 96 Service Tip - Torque Converter Leak Test Procedure
  35. 96221 OCT 96 Fog/Film on Windshield/Interior Glass
  36. 96225 OCT 96 Replacement of the Mass Air Flow Sensor as an Assembly
  37. 96207 SEP 96 Air Conditioning O-Ring Availability and Applications
  38. 96208 SEP 96 Air Conditioning Thick O-Ring Applications
  39. 961710 AUG 96 Use of R-12 Refrigerant Substitutes - Service Tip
  40. 96174 AUG 96 Water Leaks From Cowl Vent Screen
  41. 96164 JUL 96 Ford's Position On Propylene Glycol Coolant
  42. 96156 JUL 96 A/C System Service TSB List
  43. 96145 JUL 96 EATC Display Flickers with Autolamp Set On Low
  44. 96149 JUL 96 Squeal or Hoot Noise From FEAD
  45. 96129 JUN 96 Chatter During Turns After Extended Highway Driving
  46. 96122 JUN 96 Growling Noise From Steering Column While Turning
  47. 96107 MAY 96 California Reformulated Gasoline (CARFG) Service Tip
  48. 9611 JAN 96 New Torque Specs For Installing New Design Tie Rods
  49. ATRATB327 JAN 96 Output Shaft Pin Location/Updated Shaft
  50. ATRATB359 JAN 96 Revised Forward Sprag Race
  51. ATRATB358 JAN 96 Valve Body Cross Leaks
  52. 95243 DEC 95 Rocker Arm Squeak, Chirp or Knock Noise
  53. 95233 NOV 95 Air Conditioning - Water Drips On Floor
  54. 95184 SEP 95 Air Conditioning - Ford Approved Flushing
  55. 95182 SEP 95 Recycled Engine Coolant - Service Tips
  56. 95185 SEP 95 Temperature Gauge - Fluctuation/Inaccurate
  57. 951610 AUG 95 New Rotunda Fluid Changer - Service Tip
  58. 95131 JUL 95 A/C Evaporator Core-On Vehicle-Leak Test
  59. 95132 JUL 95 Temperature Gauge Reads Low/Erratic
  60. 95121 JUN 95 Windshield,Urethane Mounted, Material Usage Tip
  61. 9591 MAY 95 Antenna - Bowed Condition Only - Warranty Revision
  62. 9582 APR 95 Wiper Motor - Upgraded Service Kits
  63. 9566 MAR 95 Blower Motor - Chirp/Squeak From Blower Motor
  64. 9562 MAR 95 Brakes - Roughness During Brake Application
  65. 9561 MAR 95 Paint - Iron Particle Removal
  66. 9569 MAR 95 Service Parts - Return of Brake Shoe Kits
  67. 95512 MAR 95 Adding Refrigerant Oil Procedure
  68. 9552 MAR 95 Windshield Sealer Drips on Interior Trim
  69. 9538 FEB 95 Exhaust Moan and/or Vibration
  70. 9522 JAN 95 Air Conditioning O-Ring Removal - Service Tip
  71. 9523 JAN 95 Distance-To-Empty and Fuel; Erratic Gauge Operation
  72. 9512 JAN 95 Accelerator Cable - Diagnostic Procedure
  73. ATRATB314 JAN 95 Delayed Engagement, Shift Errors, Possible MLPS Codes
  74. ATRATB305 JAN 95 Shifts To Neutral At Heavy Throttle
  75. 94263 DEC 94 No Crank - Possible Corrosion At Starter Solenoid
  76. 94264 DEC 94 Throttle Position Sensor - Function and Diagnostic Tips
  77. 94252 DEC 94 Brake Rotor Machining Equipment and Warranty Information
  78. 94234 NOV 94 Paint Preparation Procedure And MSDS Information
  79. 94201 OCT 94 Front Seat Track Covers - Come Off When Moved Rearward
  80. 94182 SEP 94 Front Seat - Loose or Clunk When Braking or Accelerating
  81. 94172 AUG 94 Rear View Mirror - Detaches From Windshield
  82. 94169 AUG 94 Heated Exhaust Gas Oxygen Sensor Application Chart
  83. 941611 AUG 94 Overheating After Extended Idle
  84. 94142 JUL 94 Emission Control - Air Bypass Valve Replacement
  85. 94-14-3 JUL 94 R-12 Refrigerant Substitutes
  86. 94114 JUN 94 A/C - Evaporator Core and Case Assembly Application
  87. 94115 JUN 94 Heater/ A/C - Cold Engine Lockout Operation
  88. 941112 JUN 94 Rear Axle Lubricant Leakage Through Cover Vent/Hose
  89. 941011 MAY 94 Clunk From Rear End During Turning Maneuvers
  90. 94102 MAY 94 Driver's Seat Sensor Causes Doors to Lock When Exiting
  91. 941010 MAY 94 Revised Lower Intake Bolt/Stud Torque Procedure
  92. 9443 FEB 94 Remote Keyless Entry System - Service Tips
  93. 94212 JAN 94 A/C - Water Leaks From the Floor Ducts
  94. 9429 JAN 94 Air Conditioning - Poor Performance
  95. 9424 JAN 94 Instrument Panel - Cluster Finish Panel Loose
  96. 9423 JAN 94 Moon Roof - Water Leaks Between Glass and Frame
  97. 9421 JAN 94 Moon Roof - Wind Noise
  98. 9415 JAN 94 Service Parts Return of Obsolete Fuel Pressure Regulator
  99. 93265 DEC 93 Air In Power Steering System
  100. 93261 DEC 93 Heated Backlite Inoperative
  101. 932612 DEC 93 Return of Obsolete Starter Solenoids and Starter Drives
  102. 93252 DEC 93 A/C Evaporator Tube Worn By Canister Purge Hose
  103. 93253 DEC 93 A/C and Accessory Drive Belt Breakage/Squeal
  104. 93241 NOV 93 Bumper Cover Repair Materials
  105. 932410 NOV 93 Instrument Cluster Warning Lights
  106. 932412 NOV 93 Remote Keyless Entry System
  107. 93248 NOV 93 Rough Idle/Hesitation/ Poor Heater Output
  108. 932318 NOV 93 AOD Transmission - Diagnostic Information
  109. 93236 NOV 93 EGO Sensors - Silicone Contamination
  110. 932314 NOV 93 Engine Gasket Surface Cleaning Procedures
  111. 93231 NOV 93 Moon Roof - Wind Noise When Fully Open
  112. 93223 OCT 93 Steering Wheel - Grunt Noise After Full Lock Turn
  113. 93211 OCT 93 Glass - Iridescence or Mottling In Tempered Glass
  114. ATRATB191 OCT 93 Failsafe Modes - Computer Shifted Transmissions
  115. 93206 SEP 93 Air Conditioning - Use of Correct Fluorescent Tracer DYE
  116. 9319B6 SEP 93 Body Collision Repair Manual Revised
  117. 9319B5 SEP 93 Instrument Cluster Pinpoint Tests Revised
  118. 93197 SEP 93 AOD Transmission - Shudder In Reverse
  119. 93191 SEP 93 Sheet Metal - Upper Quarter Panel Sink Marks
  120. 93157 JUL 93 Fuel Injectors - Identification Information
  121. 931511 JUL 93 Labor Times Standards
  122. 93132 JUN 93 Tie Rod End (Inner) - Replacement Procedure
  123. 9384 APR 93 Exterior Clearcoat May Crack, Erode or Peel Off
  124. 9363 MAR 93 Rear Brake Pulsation
  125. 9359 MAR 93 A/C Insufficient Cooling At Idle
  126. 9353 MAR 93 Bumper Covers - Minor Surface Damage Repair Guidelines
  127. 9322 JAN 93 Power Door Lock Inoperative
  128. 93110 JAN 93 Cooling System - Proper Fluid Concentration
  129. 92264 DEC 92 Poor or Inadequate A/C Cooling
  130. 92255 DEC 92 A/C Application Chart For the FX15 Clutch, Coil & Pulley
  131. 92252 DEC 92 Engine Repair Tips to Avoid Potential Engine Damage
  132. 92246 NOV 92 FX15 A/C Compressor - Oil Recovery & Measuring Procedure
  133. 922410 NOV 92 New Short Lip Piston Seals - Apd, AODE and AODEW (A/T)
  134. 92243 NOV 92 Service Engine Soon Lamp On With No Self Test Code
  135. 92205 SEP 92 A/C Clutch Slip At High Ambient Temperature
  136. 92201 SEP 92 Paint Color Chart Aftermarket Supplier Cross Reference
  137. ATRATB132 SEP 92 Intermittent Electrical Problems
  138. 92184 AUG 92 A/C FX-15 Compressor Oil Recovery & Measuring Procedures
  139. 92174 AUG 92 Moan From A/C Compressor At Idle to 1,500RPM
  140. 92104 MAY 92 Electrical/Vacuum/Troubleshooting Manual Improvements
  141. 9244 FEB 92 Overview of EEC-IV Self-Test Codes and MIL Service Tips
  142. ATRATB078 NOV 91 How To Use A Pressure Gauge - Automatic Trans.
  143. ATRATB028 OCT 90 Engine Testing With A Vacuum Gauge - Auto Trans.
  144. ATRATB9002006 FEB 90 Automatic Transmission Fluid
  145. ATRATB8930 OCT 89 Automatic Transmission Math Part 2
  146. ATRATB8927 SEP 89 20 Steps To successful Auto Transmission Repair
  147. ATRATB8923 AUG 89 Automatic Transmission Math Formulas
  148. ATRATB8754 SEP 87 All Automatics - Front Bushing Wear
  149. ATRATB8748 AUG 87 Metal Sealing Rings - Automatic Transmissions
ALLDATA has obtained this information from the original
equipment manufacturers and others and ALLDATA believes it to be reliable.
However, ALLDATA makes no warranty regarding the information, express or
implied, and accepts no responsibility for the accurancy or completeness
of the information provided.
In no event shall ALLDATA be liable for any damages arising from the use or
misuse of this information, including, but not limited to, any direct, indirect,
incidental, special or consequential damages arising out of the use or inability
to use this information.
Copyright © 1996-2000 ALLDATA
LLC
. All Rights Reserved.
1 - 1 of 2 Posts
Status
