Status
Not open for further replies.
1 - 1 of 2 Posts
Bulletins for 1994 Ford Thunderbird V6-232 3.8L SC
General Recalls
TSB Number Issue Date TSB Title
  1. 95B79 JAN 95 Remote Keyless Entry System Transmitters
Service Bulletins
  1. 99-9-6 MAY 99 A/T-Delayed or No 2-3 Upshift, FQR Remanufactured 4R70W
  2. 99-8-16 MAY 99 Motor Oil-SAE 5W-30 Viscosity Grade Recommendation
  3. 99-6-3 APR 99 Wire Splicing And Wire Harness Terminal Repair Kit
  4. 99-4-3 MAR 99 Reprogramming Powertrain Control Modules-Out of Vehicle
  5. 98-26-2 JAN 99 Tips To Resolve Volatility Related Driveability Concerns
  6. 98-23-10 NOV 98 Mass Air Flow Sensor Contamination-Service Tip
  7. 98-20-10 OCT 98 Buzz/Rattle Noise-Loose Catalyst Or Muffler Heat Shield
  8. 98-18-14 SEP 98 A/C-Water Drips On Floor-High Blower/MAX-NORMAL A/C Mode
  9. 98-17-1 SEP 98 Seat-Leather Cleaning Procedure-Service Tip
  10. 98-12-5 JUN 98 A/C-Filtering Refrigerant After Compressor Replacement
  11. 98-12-8 JUN 98 A/C-Identifying Non-Ford Approved Refrigerants
  12. 98-10-8 MAY 98 A/T-Forward Clutch Service Tip, AODE/4R70W
  13. 98-9-9 MAY 98 Fuel Injectors, Non-Warranty Reimbursement Testing
  14. 98-8-7 APR 98 A/T-Shudder/Vibration Over 35 mph, AODE/4R70W
  15. 98-8-8 APR 98 Automatic Transmission Fluid Usage Charts
  16. 98-7-4 APR 98 Oil Leaks-New Silicone Gasket And Sealant
  17. 98-7-3 APR 98 Whining/Buzzing Noise Through Radio Speaker
  18. 98-5A-6 MAR 98 Anti-Lock Brakes Cycling On Rough Roads
  19. 98-5A-5 MAR 98 Available Hub-Mount Brake Rotor Machining Equipment
  20. 98-5A-11 MAR 98 Brakes-Elimination Of Sanding Rotors And Drums
  21. 98-5A-13 MAR 98 Brakes-New Application-Silicone Compound/Grease
  22. 98-5A-4 MAR 98 Preventing Brake Vibration, Lug Nut Torque Procedures
  23. 98-5A-18 MAR 98 Roughness During Brake Application, 65 to 0 MPH
  24. 98-5-2 MAR 98 Tire Company Telephone Numbers - Customer Assistance
  25. 98-2-7 FEB 98 Air Conditioning Musty And Mildew Type Odors
  26. 97-25-5 DEC 97 Chirping/Squeaking From Blower Motor At Low Speeds
  27. 97-24-13 NOV 97 Remote Keyless Entry (RKE) Diagnostic Service Tips
  28. 97-22-1 OCT 97 Revised Delta Pressure Feedback EGR (DPFE) Voltage Range
  29. 97-19-4 SEP 97 Brake and Rotor Service Tips
  30. 97-19-11 SEP 97 On-Vehicle Heater Core Pressure Test For Warranty Claim
  31. 97-18-4 SEP 97 Radio Am Band Static While Driving
  32. 97-17-2 AUG 97 Rear View Mirror Reattachment
  33. 97-17-16 AUG 97 Transmission Oil Cooler Leak Service Tip
  34. 97-16-7 AUG 97 AODE/4R70W Transmission Service Tip
  35. 97-12-1 JUN 97 Windnoise Emanating from Moonroof
  36. 97-11-11 MAY 97 AODE/4R70W Transmission Erratic or Prolonged 1-2 Shift
  37. 97-15-5 MAY 97 Service Tip - Refrigerant Oil Refill Capacity
  38. 97-10-5 MAY 97 Air Conditioning Compressor Failure From Low Oil
  39. 97-9-8 APR 97 Service Tip - Reprogramming the PCM
  40. 9788 APR 97 Service Tips - Electronic Automatic Temperature Control
  41. 97811 APR 97 Whining/Howling Noise from Rear Axle
  42. 9768 MAR 97 Fuel Economy - Customer Expectations Vs. Vehicle Usage
  43. 962612 DEC 96 Torque Converter Cleaning and Replacement Guidelines
  44. 962517 DEC 96 Shudder or Vibration Under LIght to Moderate Throttle
  45. 96246 NOV 96 Electrical Diode Identification and Replacement
  46. 96249 NOV 96 Service Tip - Torque Converter Leak Test Procedure
  47. 96221 OCT 96 Fog/Film on Windshield/Interior Glass
  48. 96225 OCT 96 Replacement of the Mass Air Flow Sensor as an Assembly
  49. 96207 SEP 96 Air Conditioning O-Ring Availability and Applications
  50. 96208 SEP 96 Air Conditioning Thick O-Ring Applications
  51. 96174 AUG 96 Water Leaks From Cowl Vent Screen
  52. 96164 JUL 96 Ford's Position On Propylene Glycol Coolant
  53. 96156 JUL 96 A/C System Service TSB List
  54. 96145 JUL 96 EATC Display Flickers with Autolamp Set On Low
  55. 96149 JUL 96 Squeal or Hoot Noise From FEAD
  56. 96129 JUN 96 Chatter During Turns After Extended Highway Driving
  57. 96122 JUN 96 Growling Noise From Steering Column While Turning
  58. 96107 MAY 96 California Reformulated Gasoline (CARFG) Service Tip
  59. 96106 MAY 96 NGS Tester - Incorrect Display During Diagnostics
  60. 9642 FEB 96 Steering - Power Increase in Effort at Low Speeds
  61. 9611 JAN 96 New Torque Specs For Installing New Design Tie Rods
  62. ATRATB327 JAN 96 Output Shaft Pin Location/Updated Shaft
  63. ATRATB359 JAN 96 Revised Forward Sprag Race
  64. ATRATB358 JAN 96 Valve Body Cross Leaks
  65. 95243 DEC 95 Rocker Arm Squeak, Chirp or Knock Noise
  66. 95233 NOV 95 Air Conditioning - Water Drips On Floor
  67. 95211 OCT 95 Air Bag Modules - Discolored/Marred Covers
  68. 95184 SEP 95 Air Conditioning - Ford Approved Flushing
  69. 95182 SEP 95 Recycled Engine Coolant - Service Tips
  70. 95185 SEP 95 Temperature Gauge - Fluctuation/Inaccurate
  71. 951610 AUG 95 New Rotunda Fluid Changer - Service Tip
  72. 95131 JUL 95 A/C Evaporator Core-On Vehicle-Leak Test
  73. 95132 JUL 95 Temperature Gauge Reads Low/Erratic
  74. 95121 JUN 95 Windshield,Urethane Mounted, Material Usage Tip
  75. 9591 MAY 95 Antenna - Bowed Condition Only - Warranty Revision
  76. 9584 APR 95 Leaks - Reusable Pan Gasket and Filter
  77. 9583 APR 95 Transmission - Delayed/Slow/Soft Upshifts
  78. 9566 MAR 95 Blower Motor - Chirp/Squeak From Blower Motor
  79. 9562 MAR 95 Brakes - Roughness During Brake Application
  80. 9561 MAR 95 Paint - Iron Particle Removal
  81. 9569 MAR 95 Service Parts - Return of Brake Shoe Kits
  82. 9554 MAR 95 A/C Register Misaligned
  83. 95512 MAR 95 Adding Refrigerant Oil Procedure
  84. 95515 MAR 95 Intermittent Loss of Torque at 3-4 Upshift
  85. 9552 MAR 95 Windshield Sealer Drips on Interior Trim
  86. 95313 FEB 95 Possible Water Intrusion Of The MLP/TR Sensor
  87. 9522 JAN 95 Air Conditioning O-Ring Removal - Service Tip
  88. 9523 JAN 95 Distance-To-Empty and Fuel; Erratic Gauge Operation
  89. 9524 JAN 95 Radiator - New Manufacturing Process
  90. 9512 JAN 95 Accelerator Cable - Diagnostic Procedure
  91. ATRATB314 JAN 95 Delayed Engagement, Shift Errors, Possible MLPS Codes
  92. ATRATB305 JAN 95 Shifts To Neutral At Heavy Throttle
  93. 94269 DEC 94 AODE/4R70W - Delayed or No Forward Engagement
  94. 94263 DEC 94 No Crank - Possible Corrosion At Starter Solenoid
  95. 94266 DEC 94 Release of R-134a Fluorescent Dye
  96. 94264 DEC 94 Throttle Position Sensor - Function and Diagnostic Tips
  97. 94252 DEC 94 Brake Rotor Machining Equipment and Warranty Information
  98. 94234 NOV 94 Paint Preparation Procedure And MSDS Information
  99. 94235 NOV 94 Thumping/Clacking Noise While Braking
  100. 94225 OCT 94 Outside Temp Display Intermitt. Indicates -40 Degrees
  101. 94206 OCT 94 A/C Service Tip - Oil Visible At Spring Lock Couplers
  102. 94201 OCT 94 Front Seat Track Covers - Come Off When Moved Rearward
  103. 94204 OCT 94 Heater-A/C - Metric Conversion Option for Canada
  104. 94199 SEP 94 Inaccurate or Erratic Heater/Air Conditioner Operation
  105. 94197 SEP 94 Non-Mating Condition - Harness Connector/Ignition Switch
  106. 94182 SEP 94 Front Seat - Loose or Clunk When Braking or Accelerating
  107. 94172 AUG 94 Rear View Mirror - Detaches From Windshield
  108. 94169 AUG 94 Heated Exhaust Gas Oxygen Sensor Application Chart
  109. 94141 JUL 94 Instrument Panel - Glare Form Cluster
  110. 94135 JUN 94 No Crank In Cold Weather
  111. 94114 JUN 94 A/C - Evaporator Core and Case Assembly Application
  112. 94115 JUN 94 Heater/ A/C - Cold Engine Lockout Operation
  113. 94117 JUN 94 Oil Filter Balloons & Eventually Leaks
  114. 941112 JUN 94 Rear Axle Lubricant Leakage Through Cover Vent/Hose
  115. 941011 MAY 94 Clunk From Rear End During Turning Maneuvers
  116. 94102 MAY 94 Driver's Seat Sensor Causes Doors to Lock When Exiting
  117. 9478 APR 94 Ignition Control Module Connector Update
  118. 9466 MAR 94 A/T (AODE/4R70W) - Shifting Concerns
  119. 9443 FEB 94 Remote Keyless Entry System - Service Tips
  120. 94212 JAN 94 A/C - Water Leaks From the Floor Ducts
  121. 9428 JAN 94 Platinum Spark Plugs - Identification/Location
  122. 9415 JAN 94 Service Parts Return of Obsolete Fuel Pressure Regulator
  123. 93265 DEC 93 Air In Power Steering System
  124. 93261 DEC 93 Heated Backlite Inoperative
  125. 932612 DEC 93 Return of Obsolete Starter Solenoids and Starter Drives
  126. 93241 NOV 93 Bumper Cover Repair Materials
  127. 932412 NOV 93 Remote Keyless Entry System
  128. 93248 NOV 93 Rough Idle/Hesitation/ Poor Heater Output
  129. 93236 NOV 93 EGO Sensors - Silicone Contamination
  130. 93231 NOV 93 Moon Roof - Wind Noise When Fully Open
  131. 93228 OCT 93 AODE/4R70W Transmission W/Orange Tag - Service Procedure
  132. 93211 OCT 93 Glass - Iridescence or Mottling In Tempered Glass
  133. ATRATB191 OCT 93 Failsafe Modes - Computer Shifted Transmissions
  134. 9244 FEB 92 Overview of EEC-IV Self-Test Codes and MIL Service Tips
  135. ATRATB078 NOV 91 How To Use A Pressure Gauge - Automatic Trans.
  136. ATRATB028 OCT 90 Engine Testing With A Vacuum Gauge - Auto Trans.
  137. ATRATB9002006 FEB 90 Automatic Transmission Fluid
  138. ATRATB8930 OCT 89 Automatic Transmission Math Part 2
  139. ATRATB8927 SEP 89 20 Steps To successful Auto Transmission Repair
  140. ATRATB8923 AUG 89 Automatic Transmission Math Formulas
  141. ATRATB8754 SEP 87 All Automatics - Front Bushing Wear
  142. ATRATB8748 AUG 87 Metal Sealing Rings - Automatic Transmissions
ALLDATA has obtained this information from the original
equipment manufacturers and others and ALLDATA believes it to be reliable.
However, ALLDATA makes no warranty regarding the information, express or
implied, and accepts no responsibility for the accurancy or completeness
of the information provided.
In no event shall ALLDATA be liable for any damages arising from the use or
misuse of this information, including, but not limited to, any direct, indirect,
incidental, special or consequential damages arising out of the use or inability
to use this information.
Copyright © 1996-2000 ALLDATA
LLC
. All Rights Reserved.
1 - 1 of 2 Posts
Status
