Status
Not open for further replies.
1 - 1 of 2 Posts
Bulletins for 1994 Ford Thunderbird V8-281 4.6L SOHC
General Recalls
TSB Number Issue Date TSB Title
  1. 95B79 JAN 95 Remote Keyless Entry System Transmitters
Service Bulletins
  1. 99-9-6 MAY 99 A/T-Delayed or No 2-3 Upshift, FQR Remanufactured 4R70W
  2. 99-8-16 MAY 99 Motor Oil-SAE 5W-30 Viscosity Grade Recommendation
  3. 99-6-3 APR 99 Wire Splicing And Wire Harness Terminal Repair Kit
  4. 99-4-3 MAR 99 Reprogramming Powertrain Control Modules-Out of Vehicle
  5. 98-26-2 JAN 99 Tips To Resolve Volatility Related Driveability Concerns
  6. 98-23-10 NOV 98 Mass Air Flow Sensor Contamination-Service Tip
  7. 98-20-10 OCT 98 Buzz/Rattle Noise-Loose Catalyst Or Muffler Heat Shield
  8. 98-18-14 SEP 98 A/C-Water Drips On Floor-High Blower/MAX-NORMAL A/C Mode
  9. 98-17-1 SEP 98 Seat-Leather Cleaning Procedure-Service Tip
  10. 98-12-5 JUN 98 A/C-Filtering Refrigerant After Compressor Replacement
  11. 98-12-8 JUN 98 A/C-Identifying Non-Ford Approved Refrigerants
  12. 98-10-8 MAY 98 A/T-Forward Clutch Service Tip, AODE/4R70W
  13. 98-9-9 MAY 98 Fuel Injectors, Non-Warranty Reimbursement Testing
  14. 98-8-7 APR 98 A/T-Shudder/Vibration Over 35 mph, AODE/4R70W
  15. 98-8-8 APR 98 Automatic Transmission Fluid Usage Charts
  16. 98-7-4 APR 98 Oil Leaks-New Silicone Gasket And Sealant
  17. 98-7-3 APR 98 Whining/Buzzing Noise Through Radio Speaker
  18. 98-5A-6 MAR 98 Anti-Lock Brakes Cycling On Rough Roads
  19. 98-5A-5 MAR 98 Available Hub-Mount Brake Rotor Machining Equipment
  20. 98-5A-11 MAR 98 Brakes-Elimination Of Sanding Rotors And Drums
  21. 98-5A-13 MAR 98 Brakes-New Application-Silicone Compound/Grease
  22. 98-5A-4 MAR 98 Preventing Brake Vibration, Lug Nut Torque Procedures
  23. 98-5A-18 MAR 98 Roughness During Brake Application, 65 to 0 MPH
  24. 98-5-2 MAR 98 Tire Company Telephone Numbers - Customer Assistance
  25. 98-3-4 FEB 98 Water Contamination Of Air Filter And Mass Air Sensor
  26. 98-2-7 FEB 98 Air Conditioning Musty And Mildew Type Odors
  27. 97-25-5 DEC 97 Chirping/Squeaking From Blower Motor At Low Speeds
  28. 97-24-13 NOV 97 Remote Keyless Entry (RKE) Diagnostic Service Tips
  29. 97-22-1 OCT 97 Revised Delta Pressure Feedback EGR (DPFE) Voltage Range
  30. 97-19-4 SEP 97 Brake and Rotor Service Tips
  31. 97-19-11 SEP 97 On-Vehicle Heater Core Pressure Test For Warranty Claim
  32. 97-18-4 SEP 97 Radio Am Band Static While Driving
  33. 97-17-7 AUG 97 Malfunction Indicator Lamp and/or O/D Lamp Flashing
  34. 97-17-2 AUG 97 Rear View Mirror Reattachment
  35. 97-17-16 AUG 97 Transmission Oil Cooler Leak Service Tip
  36. 97-16-7 AUG 97 AODE/4R70W Transmission Service Tip
  37. 97-12-1 JUN 97 Windnoise Emanating from Moonroof
  38. 97-11-11 MAY 97 AODE/4R70W Transmission Erratic or Prolonged 1-2 Shift
  39. 97-15-5 MAY 97 Service Tip - Refrigerant Oil Refill Capacity
  40. 97-10-5 MAY 97 Air Conditioning Compressor Failure From Low Oil
  41. 97-9-8 APR 97 Service Tip - Reprogramming the PCM
  42. 9788 APR 97 Service Tips - Electronic Automatic Temperature Control
  43. 97811 APR 97 Whining/Howling Noise from Rear Axle
  44. 9768 MAR 97 Fuel Economy - Customer Expectations Vs. Vehicle Usage
  45. 962612 DEC 96 Torque Converter Cleaning and Replacement Guidelines
  46. 962517 DEC 96 Shudder or Vibration Under LIght to Moderate Throttle
  47. 96246 NOV 96 Electrical Diode Identification and Replacement
  48. 96249 NOV 96 Service Tip - Torque Converter Leak Test Procedure
  49. 96234 NOV 96 MIL Intermittent, DTCs 332, P1407, P1408, Detonation
  50. 96221 OCT 96 Fog/Film on Windshield/Interior Glass
  51. 96225 OCT 96 Replacement of the Mass Air Flow Sensor as an Assembly
  52. 96207 SEP 96 Air Conditioning O-Ring Availability and Applications
  53. 96208 SEP 96 Air Conditioning Thick O-Ring Applications
  54. 96174 AUG 96 Water Leaks From Cowl Vent Screen
  55. 96164 JUL 96 Ford's Position On Propylene Glycol Coolant
  56. 96156 JUL 96 A/C System Service TSB List
  57. 96145 JUL 96 EATC Display Flickers with Autolamp Set On Low
  58. 96149 JUL 96 Squeal or Hoot Noise From FEAD
  59. 96148 JUL 96 Squealing Noise From FEAD
  60. 96129 JUN 96 Chatter During Turns After Extended Highway Driving
  61. 96122 JUN 96 Growling Noise From Steering Column While Turning
  62. 96107 MAY 96 California Reformulated Gasoline (CARFG) Service Tip
  63. 96106 MAY 96 NGS Tester - Incorrect Display During Diagnostics
  64. 9642 FEB 96 Steering - Power Increase in Effort at Low Speeds
  65. 9611 JAN 96 New Torque Specs For Installing New Design Tie Rods
  66. ATRATB327 JAN 96 Output Shaft Pin Location/Updated Shaft
  67. ATRATB359 JAN 96 Revised Forward Sprag Race
  68. ATRATB358 JAN 96 Valve Body Cross Leaks
  69. 95233 NOV 95 Air Conditioning - Water Drips On Floor
  70. 95211 OCT 95 Air Bag Modules - Discolored/Marred Covers
  71. 95184 SEP 95 Air Conditioning - Ford Approved Flushing
  72. 95182 SEP 95 Recycled Engine Coolant - Service Tips
  73. 95185 SEP 95 Temperature Gauge - Fluctuation/Inaccurate
  74. 951610 AUG 95 New Rotunda Fluid Changer - Service Tip
  75. 95131 JUL 95 A/C Evaporator Core-On Vehicle-Leak Test
  76. 95132 JUL 95 Temperature Gauge Reads Low/Erratic
  77. 95121 JUN 95 Windshield,Urethane Mounted, Material Usage Tip
  78. 9591 MAY 95 Antenna - Bowed Condition Only - Warranty Revision
  79. 9584 APR 95 Leaks - Reusable Pan Gasket and Filter
  80. 9583 APR 95 Transmission - Delayed/Slow/Soft Upshifts
  81. 9566 MAR 95 Blower Motor - Chirp/Squeak From Blower Motor
  82. 9562 MAR 95 Brakes - Roughness During Brake Application
  83. 9561 MAR 95 Paint - Iron Particle Removal
  84. 9569 MAR 95 Service Parts - Return of Brake Shoe Kits
  85. 9554 MAR 95 A/C Register Misaligned
  86. 95512 MAR 95 Adding Refrigerant Oil Procedure
  87. 95515 MAR 95 Intermittent Loss of Torque at 3-4 Upshift
  88. 9552 MAR 95 Windshield Sealer Drips on Interior Trim
  89. 95313 FEB 95 Possible Water Intrusion Of The MLP/TR Sensor
  90. 9522 JAN 95 Air Conditioning O-Ring Removal - Service Tip
  91. 9523 JAN 95 Distance-To-Empty and Fuel; Erratic Gauge Operation
  92. 9524 JAN 95 Radiator - New Manufacturing Process
  93. 9512 JAN 95 Accelerator Cable - Diagnostic Procedure
  94. ATRATB314 JAN 95 Delayed Engagement, Shift Errors, Possible MLPS Codes
  95. ATRATB305 JAN 95 Shifts To Neutral At Heavy Throttle
  96. 94269 DEC 94 AODE/4R70W - Delayed or No Forward Engagement
  97. 94266 DEC 94 Release of R-134a Fluorescent Dye
  98. 94264 DEC 94 Throttle Position Sensor - Function and Diagnostic Tips
  99. 94252 DEC 94 Brake Rotor Machining Equipment and Warranty Information
  100. 94234 NOV 94 Paint Preparation Procedure And MSDS Information
  101. 94235 NOV 94 Thumping/Clacking Noise While Braking
  102. 94223 OCT 94 Fuel Injector Ticking Noise At Idle
  103. 94224 OCT 94 Idle Air Bypass Valve Noise Or Moan
  104. 94225 OCT 94 Outside Temp Display Intermitt. Indicates -40 Degrees
  105. 94206 OCT 94 A/C Service Tip - Oil Visible At Spring Lock Couplers
  106. 94201 OCT 94 Front Seat Track Covers - Come Off When Moved Rearward
  107. 94204 OCT 94 Heater-A/C - Metric Conversion Option for Canada
  108. 94199 SEP 94 Inaccurate or Erratic Heater/Air Conditioner Operation
  109. 94197 SEP 94 Non-Mating Condition - Harness Connector/Ignition Switch
  110. 94182 SEP 94 Front Seat - Loose or Clunk When Braking or Accelerating
  111. 94172 AUG 94 Rear View Mirror - Detaches From Windshield
  112. 94169 AUG 94 Heated Exhaust Gas Oxygen Sensor Application Chart
  113. 94141 JUL 94 Instrument Panel - Glare Form Cluster
  114. 94135 JUN 94 No Crank In Cold Weather
  115. 94114 JUN 94 A/C - Evaporator Core and Case Assembly Application
  116. 94115 JUN 94 Heater/ A/C - Cold Engine Lockout Operation
  117. 94117 JUN 94 Oil Filter Balloons & Eventually Leaks
  118. 941112 JUN 94 Rear Axle Lubricant Leakage Through Cover Vent/Hose
  119. 941011 MAY 94 Clunk From Rear End During Turning Maneuvers
  120. 94102 MAY 94 Driver's Seat Sensor Causes Doors to Lock When Exiting
  121. 9478 APR 94 Ignition Control Module Connector Update
  122. 9466 MAR 94 A/T (AODE/4R70W) - Shifting Concerns
  123. 9443 FEB 94 Remote Keyless Entry System - Service Tips
  124. 94212 JAN 94 A/C - Water Leaks From the Floor Ducts
  125. 9415 JAN 94 Service Parts Return of Obsolete Fuel Pressure Regulator
  126. 93265 DEC 93 Air In Power Steering System
  127. 93261 DEC 93 Heated Backlite Inoperative
  128. 932612 DEC 93 Return of Obsolete Starter Solenoids and Starter Drives
  129. 93241 NOV 93 Bumper Cover Repair Materials
  130. 932412 NOV 93 Remote Keyless Entry System
  131. 93248 NOV 93 Rough Idle/Hesitation/ Poor Heater Output
  132. 93236 NOV 93 EGO Sensors - Silicone Contamination
  133. 93231 NOV 93 Moon Roof - Wind Noise When Fully Open
  134. 93228 OCT 93 AODE/4R70W Transmission W/Orange Tag - Service Procedure
  135. 93211 OCT 93 Glass - Iridescence or Mottling In Tempered Glass
  136. ATRATB191 OCT 93 Failsafe Modes - Computer Shifted Transmissions
  137. 9244 FEB 92 Overview of EEC-IV Self-Test Codes and MIL Service Tips
  138. ATRATB078 NOV 91 How To Use A Pressure Gauge - Automatic Trans.
  139. ATRATB028 OCT 90 Engine Testing With A Vacuum Gauge - Auto Trans.
  140. ATRATB9002006 FEB 90 Automatic Transmission Fluid
  141. ATRATB8930 OCT 89 Automatic Transmission Math Part 2
  142. ATRATB8927 SEP 89 20 Steps To successful Auto Transmission Repair
  143. ATRATB8923 AUG 89 Automatic Transmission Math Formulas
  144. ATRATB8754 SEP 87 All Automatics - Front Bushing Wear
  145. ATRATB8748 AUG 87 Metal Sealing Rings - Automatic Transmissions
ALLDATA has obtained this information from the original
equipment manufacturers and others and ALLDATA believes it to be reliable.
However, ALLDATA makes no warranty regarding the information, express or
implied, and accepts no responsibility for the accurancy or completeness
of the information provided.
In no event shall ALLDATA be liable for any damages arising from the use or
misuse of this information, including, but not limited to, any direct, indirect,
incidental, special or consequential damages arising out of the use or inability
to use this information.
Copyright © 1996-2000 ALLDATA
LLC
. All Rights Reserved.
1 - 1 of 2 Posts
Status
