Status
Not open for further replies.
1 - 1 of 2 Posts
Bulletins for 1995 Ford Thunderbird V8-281 4.6L SOHC
General Recalls
TSB Number Issue Date TSB Title
  1. 95B79 JAN 95 Remote Keyless Entry System Transmitters
Service Bulletins
  1. 99-9-6 MAY 99 A/T-Delayed or No 2-3 Upshift, FQR Remanufactured 4R70W
  2. 99-8-15 MAY 99 Interior Door Trim Panel Replacement-Service Tip
  3. 99-8-16 MAY 99 Motor Oil-SAE 5W-30 Viscosity Grade Recommendation
  4. 99-6-3 APR 99 Wire Splicing And Wire Harness Terminal Repair Kit
  5. 99-4-3 MAR 99 Reprogramming Powertrain Control Modules-Out of Vehicle
  6. 99-2-3 FEB 99 Windshield Sealing For Water Leaks-Service Tip
  7. 98-26-2 JAN 99 Tips To Resolve Volatility Related Driveability Concerns
  8. 98-23-10 NOV 98 Mass Air Flow Sensor Contamination-Service Tip
  9. 98-21-6 OCT 98 Steering Wheel Nibble Felt When Driving On Rough Surface
  10. 98-20-10 OCT 98 Buzz/Rattle Noise-Loose Catalyst Or Muffler Heat Shield
  11. 98-18-14 SEP 98 A/C-Water Drips On Floor-High Blower/MAX-NORMAL A/C Mode
  12. 98-17-1 SEP 98 Seat-Leather Cleaning Procedure-Service Tip
  13. 98-12-5 JUN 98 A/C-Filtering Refrigerant After Compressor Replacement
  14. 98-12-8 JUN 98 A/C-Identifying Non-Ford Approved Refrigerants
  15. 98-10-8 MAY 98 A/T-Forward Clutch Service Tip, AODE/4R70W
  16. 98-9-9 MAY 98 Fuel Injectors, Non-Warranty Reimbursement Testing
  17. 98-8-7 APR 98 A/T-Shudder/Vibration Over 35 mph, AODE/4R70W
  18. 98-8-8 APR 98 Automatic Transmission Fluid Usage Charts
  19. 98-7-4 APR 98 Oil Leaks-New Silicone Gasket And Sealant
  20. 98-7-3 APR 98 Whining/Buzzing Noise Through Radio Speaker
  21. 98-5A-6 MAR 98 Anti-Lock Brakes Cycling On Rough Roads
  22. 98-5A-5 MAR 98 Available Hub-Mount Brake Rotor Machining Equipment
  23. 98-5A-11 MAR 98 Brakes-Elimination Of Sanding Rotors And Drums
  24. 98-5A-13 MAR 98 Brakes-New Application-Silicone Compound/Grease
  25. 98-5A-4 MAR 98 Preventing Brake Vibration, Lug Nut Torque Procedures
  26. 98-5A-18 MAR 98 Roughness During Brake Application, 65 to 0 MPH
  27. 98-5-2 MAR 98 Tire Company Telephone Numbers - Customer Assistance
  28. 98-3-4 FEB 98 Water Contamination Of Air Filter And Mass Air Sensor
  29. 98-2-7 FEB 98 Air Conditioning Musty And Mildew Type Odors
  30. 97-25-5 DEC 97 Chirping/Squeaking From Blower Motor At Low Speeds
  31. 97-24-13 NOV 97 Remote Keyless Entry (RKE) Diagnostic Service Tips
  32. 97-22-1 OCT 97 Revised Delta Pressure Feedback EGR (DPFE) Voltage Range
  33. 97-19-4 SEP 97 Brake and Rotor Service Tips
  34. 97-19-11 SEP 97 On-Vehicle Heater Core Pressure Test For Warranty Claim
  35. 97-18-4 SEP 97 Radio Am Band Static While Driving
  36. 97-17-2 AUG 97 Rear View Mirror Reattachment
  37. 97-17-16 AUG 97 Transmission Oil Cooler Leak Service Tip
  38. 97-16-7 AUG 97 AODE/4R70W Transmission Service Tip
  39. 97-12-1 JUN 97 Windnoise Emanating from Moonroof
  40. 97-11-11 MAY 97 AODE/4R70W Transmission Erratic or Prolonged 1-2 Shift
  41. 97-15-5 MAY 97 Service Tip - Refrigerant Oil Refill Capacity
  42. 97-10-5 MAY 97 Air Conditioning Compressor Failure From Low Oil
  43. 97-9-5 APR 97 Hard Starting, Long Crank, Stalling
  44. 97-9-8 APR 97 Service Tip - Reprogramming the PCM
  45. 9788 APR 97 Service Tips - Electronic Automatic Temperature Control
  46. 97811 APR 97 Whining/Howling Noise from Rear Axle
  47. 9768 MAR 97 Fuel Economy - Customer Expectations Vs. Vehicle Usage
  48. 962612 DEC 96 Torque Converter Cleaning and Replacement Guidelines
  49. 962517 DEC 96 Shudder or Vibration Under LIght to Moderate Throttle
  50. 96246 NOV 96 Electrical Diode Identification and Replacement
  51. 96249 NOV 96 Service Tip - Torque Converter Leak Test Procedure
  52. 96234 NOV 96 MIL Intermittent, DTCs 332, P1407, P1408, Detonation
  53. 96221 OCT 96 Fog/Film on Windshield/Interior Glass
  54. 96225 OCT 96 Replacement of the Mass Air Flow Sensor as an Assembly
  55. 96207 SEP 96 Air Conditioning O-Ring Availability and Applications
  56. 96208 SEP 96 Air Conditioning Thick O-Ring Applications
  57. 96174 AUG 96 Water Leaks From Cowl Vent Screen
  58. 96164 JUL 96 Ford's Position On Propylene Glycol Coolant
  59. 96156 JUL 96 A/C System Service TSB List
  60. 96145 JUL 96 EATC Display Flickers with Autolamp Set On Low
  61. 96149 JUL 96 Squeal or Hoot Noise From FEAD
  62. 96148 JUL 96 Squealing Noise From FEAD
  63. 96129 JUN 96 Chatter During Turns After Extended Highway Driving
  64. 96122 JUN 96 Growling Noise From Steering Column While Turning
  65. 96127 JUN 96 Tape May Fail To Eject From Radio
  66. 96107 MAY 96 California Reformulated Gasoline (CARFG) Service Tip
  67. 96106 MAY 96 NGS Tester - Incorrect Display During Diagnostics
  68. 9642 FEB 96 Steering - Power Increase in Effort at Low Speeds
  69. 9611 JAN 96 New Torque Specs For Installing New Design Tie Rods
  70. ATRATB358 JAN 96 Valve Body Cross Leaks
  71. 95233 NOV 95 Air Conditioning - Water Drips On Floor
  72. 95211 OCT 95 Air Bag Modules - Discolored/Marred Covers
  73. 95184 SEP 95 Air Conditioning - Ford Approved Flushing
  74. 95182 SEP 95 Recycled Engine Coolant - Service Tips
  75. 951610 AUG 95 New Rotunda Fluid Changer - Service Tip
  76. 95131 JUL 95 A/C Evaporator Core-On Vehicle-Leak Test
  77. 95132 JUL 95 Temperature Gauge Reads Low/Erratic
  78. 95121 JUN 95 Windshield,Urethane Mounted, Material Usage Tip
  79. 9591 MAY 95 Antenna - Bowed Condition Only - Warranty Revision
  80. 9584 APR 95 Leaks - Reusable Pan Gasket and Filter
  81. 9562 MAR 95 Brakes - Roughness During Brake Application
  82. 9561 MAR 95 Paint - Iron Particle Removal
  83. 9554 MAR 95 A/C Register Misaligned
  84. 95512 MAR 95 Adding Refrigerant Oil Procedure
  85. 95515 MAR 95 Intermittent Loss of Torque at 3-4 Upshift
  86. 95313 FEB 95 Possible Water Intrusion Of The MLP/TR Sensor
  87. 9522 JAN 95 Air Conditioning O-Ring Removal - Service Tip
  88. 9524 JAN 95 Radiator - New Manufacturing Process
  89. 9512 JAN 95 Accelerator Cable - Diagnostic Procedure
  90. ATRATB314 JAN 95 Delayed Engagement, Shift Errors, Possible MLPS Codes
  91. ATRATB305 JAN 95 Shifts To Neutral At Heavy Throttle
  92. 94266 DEC 94 Release of R-134a Fluorescent Dye
  93. 94264 DEC 94 Throttle Position Sensor - Function and Diagnostic Tips
  94. 94252 DEC 94 Brake Rotor Machining Equipment and Warranty Information
  95. 94239 NOV 94 Insufficient A/C Cooling Or Excessive Clutch End Gap
  96. 94234 NOV 94 Paint Preparation Procedure And MSDS Information
  97. 94235 NOV 94 Thumping/Clacking Noise While Braking
  98. 94225 OCT 94 Outside Temp Display Intermitt. Indicates -40 Degrees
  99. 94206 OCT 94 A/C Service Tip - Oil Visible At Spring Lock Couplers
  100. 94172 AUG 94 Rear View Mirror - Detaches From Windshield
  101. 9244 FEB 92 Overview of EEC-IV Self-Test Codes and MIL Service Tips
  102. ATRATB078 NOV 91 How To Use A Pressure Gauge - Automatic Trans.
  103. ATRATB028 OCT 90 Engine Testing With A Vacuum Gauge - Auto Trans.
  104. ATRATB9002006 FEB 90 Automatic Transmission Fluid
  105. ATRATB8930 OCT 89 Automatic Transmission Math Part 2
  106. ATRATB8927 SEP 89 20 Steps To successful Auto Transmission Repair
  107. ATRATB8923 AUG 89 Automatic Transmission Math Formulas
  108. ATRATB8754 SEP 87 All Automatics - Front Bushing Wear
  109. ATRATB8748 AUG 87 Metal Sealing Rings - Automatic Transmissions
ALLDATA has obtained this information from the original
equipment manufacturers and others and ALLDATA believes it to be reliable.
However, ALLDATA makes no warranty regarding the information, express or
implied, and accepts no responsibility for the accurancy or completeness
of the information provided.
In no event shall ALLDATA be liable for any damages arising from the use or
misuse of this information, including, but not limited to, any direct, indirect,
incidental, special or consequential damages arising out of the use or inability
to use this information.
Copyright © 1996-2000 ALLDATA
LLC
. All Rights Reserved.
1 - 1 of 2 Posts
Status
