Status
Not open for further replies.
1 - 1 of 2 Posts
Bulletins for 1997 Ford Thunderbird V8-281 4.6L VIN W SFI
Service Bulletins
TSB Number Issue Date TSB Title
  1. 99-9-6 MAY 99 A/T-Delayed or No 2-3 Upshift, FQR Remanufactured 4R70W
  2. 99-8-15 MAY 99 Interior Door Trim Panel Replacement-Service Tip
  3. 99-8-16 MAY 99 Motor Oil-SAE 5W-30 Viscosity Grade Recommendation
  4. 99-6-3 APR 99 Wire Splicing And Wire Harness Terminal Repair Kit
  5. 99-5-3 MAR 99 A/T-Checking Transmission Fluid Level Cold
  6. 99-4-3 MAR 99 Reprogramming Powertrain Control Modules-Out of Vehicle
  7. 99-2-3 FEB 99 Windshield Sealing For Water Leaks-Service Tip
  8. 98-26-2 JAN 99 Tips To Resolve Volatility Related Driveability Concerns
  9. 98-25-9 DEC 98 Interior Trim-Repairs To Vinyl Covered Surfaces
  10. 98-24-6 DEC 98 New Electrical Terminal Grease Released For Service
  11. 98-23-12 NOV 98 A/T-Diagnostic Trouble Codes Stored In Memory
  12. 98-23-10 NOV 98 Mass Air Flow Sensor Contamination-Service Tip
  13. 98-23-24 NOV 98 Replace/Repair Lock Component-Individual Locks Available
  14. 98-21-6 OCT 98 Steering Wheel Nibble Felt When Driving On Rough Surface
  15. 98-20-10 OCT 98 Buzz/Rattle Noise-Loose Catalyst Or Muffler Heat Shield
  16. 98-18-14 SEP 98 A/C-Water Drips On Floor-High Blower/MAX-NORMAL A/C Mode
  17. 98-18-2 SEP 98 Paint Materials For After Warranty And Warranty Repairs
  18. 98-17-1 SEP 98 Seat-Leather Cleaning Procedure-Service Tip
  19. 98-12-5 JUN 98 A/C-Filtering Refrigerant After Compressor Replacement
  20. 98-12-8 JUN 98 A/C-Identifying Non-Ford Approved Refrigerants
  21. 98-9-2 MAY 98 Door Latch/Outside Handle Stuck
  22. 98-9-9 MAY 98 Fuel Injectors, Non-Warranty Reimbursement Testing
  23. 98-8-7 APR 98 A/T-Shudder/Vibration Over 35 mph, AODE/4R70W
  24. 98-8-8 APR 98 Automatic Transmission Fluid Usage Charts
  25. 98-7-4 APR 98 Oil Leaks-New Silicone Gasket And Sealant
  26. 98-7-3 APR 98 Whining/Buzzing Noise Through Radio Speaker
  27. 98-5A-5 MAR 98 Available Hub-Mount Brake Rotor Machining Equipment
  28. 98-5A-11 MAR 98 Brakes-Elimination Of Sanding Rotors And Drums
  29. 98-5A-4 MAR 98 Preventing Brake Vibration, Lug Nut Torque Procedures
  30. 98-5A-18 MAR 98 Roughness During Brake Application, 65 to 0 MPH
  31. 98-5-2 MAR 98 Tire Company Telephone Numbers - Customer Assistance
  32. 98-3-3 FEB 98 Surface Defect Removal Without Repainting-Service Tip
  33. 98-3-4 FEB 98 Water Contamination Of Air Filter And Mass Air Sensor
  34. 98-2-7 FEB 98 Air Conditioning Musty And Mildew Type Odors
  35. 97-25-5 DEC 97 Chirping/Squeaking From Blower Motor At Low Speeds
  36. 97-24-13 NOV 97 Remote Keyless Entry (RKE) Diagnostic Service Tips
  37. 97-22-1 OCT 97 Revised Delta Pressure Feedback EGR (DPFE) Voltage Range
  38. 97-21-3 OCT 97 Industrial Fallout, Iron Particle Removal From Paint
  39. 97-19-4 SEP 97 Brake and Rotor Service Tips
  40. 97-19-11 SEP 97 On-Vehicle Heater Core Pressure Test For Warranty Claim
  41. 97-19-12 SEP 97 Return of Obsolete A/C Pressure Switches
  42. 97-18-4 SEP 97 Radio Am Band Static While Driving
  43. 97-17-2 AUG 97 Rear View Mirror Reattachment
  44. 97-17-16 AUG 97 Transmission Oil Cooler Leak Service Tip
  45. 97-13-10 JUN 97 Service Tips - Remote Keyless Entry Inoperative
  46. 97-11-11 MAY 97 AODE/4R70W Transmission Erratic or Prolonged 1-2 Shift
  47. 97-15-5 MAY 97 Service Tip - Refrigerant Oil Refill Capacity
  48. 97-10-5 MAY 97 Air Conditioning Compressor Failure From Low Oil
  49. 97-10-6 MAY 97 Shudder or Vibration while in 3rd or 4th Gear
  50. 97-9-1 APR 97 Service Tip - Rapgard Paint Protection
  51. 97-9-8 APR 97 Service Tip - Reprogramming the PCM
  52. 9788 APR 97 Service Tips - Electronic Automatic Temperature Control
  53. 9768 MAR 97 Fuel Economy - Customer Expectations Vs. Vehicle Usage
  54. 9753 MAR 97 Vibration While Driving at Highway Speeds
  55. 9735 FEB 97 A/C - R134a Tracer Dye and Three O-Ring Spring Couplers
  56. 962612 DEC 96 Torque Converter Cleaning and Replacement Guidelines
  57. 96246 NOV 96 Electrical Diode Identification and Replacement
  58. 96249 NOV 96 Service Tip - Torque Converter Leak Test Procedure
  59. 96221 OCT 96 Fog/Film on Windshield/Interior Glass
  60. 96225 OCT 96 Replacement of the Mass Air Flow Sensor as an Assembly
  61. 96201 SEP 96 1997 Paint Color Chart
  62. 96207 SEP 96 Air Conditioning O-Ring Availability and Applications
  63. 96208 SEP 96 Air Conditioning Thick O-Ring Applications
  64. 96179 AUG 96 MIL On, Any DTCs From P0300 through P0308 in Memory
  65. 96164 JUL 96 Ford's Position On Propylene Glycol Coolant
ALLDATA has obtained this information from the original
equipment manufacturers and others and ALLDATA believes it to be reliable.
However, ALLDATA makes no warranty regarding the information, express or
implied, and accepts no responsibility for the accurancy or completeness
of the information provided.
In no event shall ALLDATA be liable for any damages arising from the use or
misuse of this information, including, but not limited to, any direct, indirect,
incidental, special or consequential damages arising out of the use or inability
to use this information.
Copyright © 1996-2000 ALLDATA
LLC
. All Rights Reserved.
1 - 1 of 2 Posts
Status
