This hasn't been discussed before, and it's kinda what I'm thinking of doing.
Unfortunately - my 92 XR7's body's days are numbered. The rockers are rotten underneath the car, and some other areas are starting to look bad too. Not to mention a dent in the rear 1/4, creased door edges (walls? I didn't do the damage), and alot of worn out suspension components.
I won't fix it up, because fixed body jobs always start over again. And since alot of parts on it will be replaced with HiPo parts anyways - I should just sell this 92 and start with another one.
Which leads me to this idea. I want to find a 89+ Cougar in a junkyard, the only good parts have to be the body. There should be a few of them that are worn out by now, and aren't banged up, right? Then it's a buildup with new HiPo parts, and the powertrain and interior from my 92 - and a paint job.
How viable is this idea? I have the money and the means to transport it home, but have to find one.
Refrigerator Raider Hater
I'd search the south, away from the coasts.
Usually junkyards will not sell a body unless you sign a waiver saying it will only be used off-road. At the very least You'll have a salvage title.
As for the cost....I guess it depends on how much it is worth to you, and have much you have to spend.
I'd say $1000 would not be unreasonable for a chassis in such condition. Also, if you go with a 91-93, you'll save yourself alot of trouble at the motor vechicle and emissions departments.
Probably better off finding a car actually owned by someone with a blown engine or tranny or both, you ought to be able to pick up something like that pretty cheap.
Thats a good idea. If its just a blown engine you probably wont have a salvage titel for swapping a engine. If its straight from the junk yard you probably will. There is enough 89-92s though that are decent shape over all for cheap prices out there. Might just want to look for a better condition one over all and just ditch the one you got now if its that bad. Just a thought.
Good luck
-Shawn
Good advice - thanks guys.
I think it's probably better to find one privately, but they'll be harder to find. Who spends money advertising a $500 car that doesn't run anyways? They are out there though, I know of MANY MN12's in my area alone that have dead powertrains - unfortunately EVERY one is rotten.
My brother just sucessfully found a Mustang (Fox body) from the Olklahoma (sp?) area - when he gets back I'll have to find out if there were any MN12's in the area.
Oh yeah Shawn - my 92 isn't all that bad, but it's certainly beyond repair - once they start rusting, you can't stop it. And I don't want to pour money into a body job for it, only to have it continue rusting out on me. It's just those damn rockers!!! What a crappy design...
Anyways - I plan on simply swapping parts over, get the 92 running (with a 3.8 or something), and sell it for the costs of getting a rust free southern body going :).
