i plan to bypass my radiator when i hook the hoses up to my transcooler. what should i use to plug up the exposed holes where the metal tranny lines go in the radiator? is there some sort of screw-on cap to use?
If i were you i would take out the big nut the goes into the radiator were you hook up your metal line and take it to a hardware store and put a bolt and just put some thread tape on just incase it were to leak
I bypassed my rad when I installed a B&M style trans cooler. I plugged the holes on the rad with bolts so any fluid left in there could not leak out on my floor. Good luck
