1 - 12 of 12 Posts
I recently aquired a '95 Thunderbird and I'm looking to spruce it up a bit. I started by purchasing an '03 GT MAF sensor and I'll be ordering an Injecttech chip for it this week... now I'm looking to complete the installation. From my searches, I've decided that I'll go with the Mac CAI, however I'm not quite sure which kit to purchase. Will the '96-03 Mustang GT CAI work on my car?
The second part of my question is about the '03 GT throttle body... is it a direct swap?
Thanks...
Jedi Master
the TB will not bolt up right away you will need to swap to 96or newer intake manifold but you can use f-150 aftermarket TB's
as for the maf, it should bolt on fine, but you will need an adapter cause those mafs are bolted on not clamped on, with that chip it should be all good
Some of the 4.6 guys may correct me since i'm more of a 5.0 guy and don't have a 4.6...
Refrigerator Raider Hater
That TB will not work, and converting to a 96+ intake would cost almost as much as a 96+ engine.
The best way to use the 03GT MAF is to bolt it to the 03 GT airbox. You will need to order a wiring pigtail for the MAF. See the tech article on modular depot.
The best CAI for the money is the civic tube.
Thanks for all the replies.
GreenBird said:
That TB will not work, and converting to a 96+ intake would cost almost as much as a 96+ engine..
Really? From what I've seen, it seemed like a somewhat easier modification. I thought it's mainly the head swap and upper intake manifold swap (along with the odds and ends).
I've got the harness, thanks.:)
my buddy at harderperformance has a **** load of stock mustang intake boxes and tube call him at 913-310-9898 ask for joe hader tell him jason jobe told you to call. he's selling them pretty cheap
guitar maestro said:
send that back and get yourself an SCT chip......it the best of the best
www.superchipscustom.com
you sure about that? does J know about these inject tech chips?
joseph
karkraft.com sells a 70mm 94-95 specific t-body...I had the 70mm FRPP unit. I think that the bigger tb is a waste of money. Mine didnt seem to make much of a difference.
joseph
i thought J was with Fordchip before SCT?....guess i'm mistaken
no your right, j was with fordchip before SCT, only some of us know where he was before fordchip, and before custom chip.....
InjectTech
Formerly Fdawg97LX
Thanks...
also, the mac cai will not work on your car. there is one for the 96-97 thunderbirds but not the 94-95's. you have a front mounted throttle body and the 96-97 has a side mounted one.
Frank
1 - 12 of 12 Posts
