1 - 2 of 2 Posts
anybody ever done this? what is involved in rebuilding a caliper? whats in the kit? just wondring
If I remember correctly, there is a inner rubber seal on the caliper piston and the outer rubber seal that you can see. That's all in the kit.
Clean the piston and inner part with a FINE scotchbrite and brake fluid. You are just going to clean the gunk off. Sometimes the piston goes back in with the new seals easy, sometimes it wants to be a hassel.
But, you can do it easy enough.
1 - 2 of 2 Posts
