Fry Rice Specialist
yup.
make sure the bolt have high temp red loctite on it.
yup.
MOST definitely!! I read in a ford manual that it was 20 lbsl-ft. cost me a set of heads.
Fry Rice Specialist
And you'll need something to hold the engine from turning over.
for stock cam or pi cam at the back end of the shaft you can use a 3/8 rachet drive to hold it from turning.
for aftermarket cams there usually have a hex part size either 13/16 or 15/16 (i can't remember which) where you can put a wrench on it to hold it from turning.
