The lift over the base circle is multiplied by the rocker multiplier, which is 1.81; correct?
And if 0.050" of lift works to 0.0276", I can check duration by [2x #degrees over 0.0276"]=duration, correct?
This data was interesting:
F6LE-61271-BC
97° SEC .2190 LIFT (194° , 0.396 lift)
91° PRI .2160 (182° , 0.396 lift)
F2LE-6A271-AE
91° PRI .2185 LIFT (182° , 0.395 lift)
97° SEC .2205 (194° , 0.398 lift)
I'm still working on the encoder for degrees; I want .5 degree accuracy. :)
