Ok so the 01+ Romeo PI cams have smaller 10mm bolts for the gears as opposed to the other cams which use 12mm bolts, but do they use the same washer? It seems like there should be a washer with a smaller bolt hole for the 10mm bolt. Anyone know if they are different and the p/n if there is?
I went through this last year. I bought new washers to go with the smaller bolts, directly through Ford, only to get home and realize that they were exactly the same as the old washers. For what Ford charges for washers, I'll remember not to make that mistake again.
-Rod
