I'm about done with my swap and this is a bit confusing. I have a 2004 3.9L in my 1996 Cougar. I am using the original synchro from the Cougar and the balancer from the Mustang. The FSM for the 96 says to rotate the engine to 26° ATDC and use a synchro positioning tool. The FSM for a 97 says to rotate it to 0° and use the same tool. The FSM for the Mustang also says 0°. I would have thought the 96 and 97 would read the same.
The original balancer from the Cougar has marks from 30° BTDC to 10° ATDC and a notch that corresponds where 26° would be. The Mustang balancer only shows 10° BTDC to 10° ATDC (I assume). I have the kit of three or four synchro positioning tools. I am trying to figure out if I need to mark for 26° BTDC on the balancer, or use 0°.
Here are some pics for reference, as well as the excerpt from the 96 and 97 FSM. I found the Mustang FSM online and it reads the same as the 97.
Original 1996 balancer:
Mustang balancer:
1996 FSM (Step 5):
1997 FSM (Step 5):
Discussion Starter #2
As an update... I went ahead and tried this with it at 0° as shown in the second picture and I used the yellow tool from THIS set. She fired right up on the first try.
I find that odd the difference in setting, but hey I go with 26° and just mark the cam sensor.
After looking at the literature again, the 96 says use tool T96P-12200-A @ 26° ATDC where the 97 is T96T-12200-A @ 0°. :facepalm:
As far as I know, the 96 and 97 use the same synchro/balancer/coil/etc so I'm not sure why the book has different numbers.
