I did a search, and i found mostly engine tuning/timing etc.
What would i have to do to basically make 1st shift MUCH later at slow speeds, the same with 2nd..? Mainly so that i can stay in 1st like a manual. I hate it how my car shifts 1,2,3,OD in like 6 seconds and i'm doing 36mph in 4th. This i understand is for fuel economy, but i much rather have 1st up to like 28mph whether i'm easy on the throttle of full on WOT.
Would a speed shop be able to do this..? I don't think anything else would have to be changed either, like a/f, timing etc.
Talk to Lonnie at Blue Oval, mine shifts much later although not 28 mph, more like 20 ish.
Dave
yup the only way you can really change the shift schedule is with a chip or tuner which lonnie is the man at :)
i believe you can have the shift set to either rpm or vehicle speed. so you can program it to shift whenever you want. order a chip from lonnie. (see my sig)
