I have to change my front bumper so question is can a 97 bumper go on a 95 LX without any mods?? straight bolt on. And if not what needs to be done?
yes, but you need the pieces underneith the cover too. everything else should fit just fine (that's why there's atleast one post below this one talking about a 96-7 front end conversion) if you got the $$, pick up the headlights too. I hink the 94-5 will fit fine (if not, it's really close), but the 96-7 look much better.
-jw
13's or Mildly Broken
And if you do get the headlights, you need to get the hood too. Just so it all looks right in the front.
-Andy "Melon"
I converted mine, and the honeycomb plastic piece under the bumper cover will need to be modified or replaced with that of 97. To modify it, I just removed the two corner sections.
As suggested, if you have the $$ buy yourself the 97 headlights and a set of clear corners. Get the headlights from FiveStarFord with the member discount, saves quite a bit.
The hood will be just fine, there will just be very small gap on one section of the headlight...
